Results 1 to 15 of 15
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    Radiator Horse Shoe Clip Problems
    Been working on the car for the past few days and have been getting my ass kicked today by a plastic clip. No matter what I do the clip will not go around the sensor once in place. The hose to the radiator is fine its just the sensor. There has got to be something that I am not doing right. Any help would be wonderful
    http://www.bimmerspecialist.com/usa/parts/index/audi#
    there is all 38 cents worth of trouble
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Re: Radiator Horse Shoe Clip Problems
    push the sensor in farther , are you replacing the sensor? is their another o-ring in the sensor hole already that didnt get removed?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Sep 09 2007
    Raleigh, NC
    I had been pusing the sensor in to where I dont think it would have gone any further. I dont think that there was an o ring still in the fixture I will have to check. It just seemed like the clip did not want to open up around the sensor and wrap around it like it should.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Try it dry without an o-ring. It should be loose and fit easily. Then try it with the o-ring.
    Jim
    I Do Werk.
    Sep 09 2007
    Raleigh, NC
    thanks ill try in the morning
    Sep 09 2007
    Raleigh, NC
    Got into it again this morning and there was no O ring in the fixture and the part had snapped with me trying to get it in. its not an expensive part but no parts stores in the area offer it except the dealership which is not open on Sat. If someone lead me in the right direction as far as which O ring to get would be great. Im thinking it is this one http://www.bimmerspecialist.com/usa/parts/index/audi# 2001 audi S4 Coolant Flang Plug. I searched O rings and think that is the one. It wont give me a direct link to the parts page sorry for that. Still had trouble getting the clip in without the O ring. Any tips appreciated
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    your links arent working bud.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Sep 09 2007
    Raleigh, NC
    Working on that. The part number for the O ring is N 903 168 02 and the part for the horse shoe clip is 032 121 142. Could not get it to come up on the exact page so you can just plug in the part number at the website might help out a bit.
    Sep 09 2007
    Raleigh, NC
    still no luck with that guess im going to have to visit the stealership again on monday
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    thats wierd , ive replaced about 70 of those and haven't had this problem with a single one
    Senior Member Two Rings galvan11's Avatar
    Aug 20 2007
    02 pearl gt s4, vw passat, 06 cbr
    south
    You are probably putting in the clip the wrong way. I had the same problem and took me about 5 minutes to realize how the clip went in.
    Sep 09 2007
    Raleigh, NC
    ok so the sensor port comes out of the hose connecting to the radiator and has two slots opposite of each other. I have been going at it by trying to slide the clip in through one of the slits around the sensor and coming out the other slit. i didnt see any way else to do it but maybe it is wrong because it didnt even want to fit in withought the sensor in place.
    Sep 09 2007
    Raleigh, NC
    Here is what i have been doing and if im wrong please someone correct me just as it shows it there is how I have been going about it.
    Sep 09 2007
    Raleigh, NC
    OK I think I figured it out and feel like a jackass about it now. Rotate clip quarter turn from what I have depicted above sliding the clip over the plastic with the prongs supporting the sensor and holding in place. Thanks for the help
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    hehe yeah qtr turn and your good to go .
