Results 1 to 30 of 30
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Here we go again....
    Well i recieved my driveshaft today, but when i went to take my old one off i couldnt get the bolts out on the tail end(driveshaft to rear diff). I tried everything i could think of and NOTHING worked. So i got out the air ratchet hoping it could do get them out, but it was like bringing a spork to a sword fight. So i went and got my small impact wrench and turned it all the way down to 100ft/lbs and it didnt budge it, turned it to 150ft/lbs and it still didnt budge it, turned it to 200ft/lbs and it instantly stripped it. Great! So i turn the driveshaft to get to the other bolts, only to realize that i just stripped the ONLY bolt that wasnt already stripped. Needless to say, im pretty f#@$&ng annoyed right now. Id really like to find the guy who did the work on this thing and give him a swiff kick to the testicles, because this is only the 5th set of nuts/bolts that were stripped on it.
    After messing with it for atleast an hour i finally got one out by hammering in a t40 torx bit and breaking it loose. Theres thread sealer from the head of the bolt all the way down...and only 1/3rd of the bolt is actually threaded. Ive never seen any thread sealer like this, it actually looks like jb weld or some sort of epoxy.
    Anyway, does anyone have any hints or tricks on how i could get these little bastards out? Ive tried vice grips, bolt extractor, hammering in hex bits, and i actually tried to braek one off with the air hammer but i wouldve messed up the driveshaft and not been able to get my core charge back. Oh, and it was also douched with wd40 2hrs before i worked on it, i heated up every bolt with a torch, and tried the old school hammer smacking to break the threads loose. Im completely stumped, ive never seen anything like this in my life. Any and all help would be greatly appreciated.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Re: Here we go again....
    the red thread lock paste is factory, i always take them out with a impact and a 6mm allen socket
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Well the impact didnt really help me at all lol. Also, this wasnt factory paste(which is blue on these bolts btw)...it was gray and the whole bolt was covered in it. Thanks for the bump though.
    I really need to get these things out. Ive gotta get new bolts anyway so i dont really care if i thrash these...i just want them gone.
    2014 Fiat 500 Sport
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    get a 12 point 12mm i think or maybe 11mm socket and hammer it over thats what i use when i strip the centers
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Aight ill give that a try tomorrow. If that doesnt work i might just weld a nut on it and see if i can break it off with the impact.
    2014 Fiat 500 Sport
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    lift weights. nycvr6 unscrews those bolts with his fingers.
    SBSC
    I also like to live dangerously.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by FrimmelNoJerz View Post
    HA!
    - Clint
    Sep 19 2006
    Boston
    sorry to hear that maybe you can use some of this
    THE ALMIGHTY THE ALL MAGICAL
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Heat usually melts threadlocker which makes removal much easier. Rather than using a torch you can hold the tip of a soldering iron in the head of the bolt. Give it a minute and it should be hot enough to remove easily.
    Jim
    I Do Werk.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Trust me...it was definitely hot enough. Besides, even if i could break the thread locker i still have to somehow get the stripped bolts out.
    As far as taking it off with my fingers...i thought about that but i dont know mow much torque the rear end can handle. When i put the big arm on something, either it gives or everything its attached to gives lol.
    2014 Fiat 500 Sport
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    vice grips is always a great option... heat the bolt up, get the vice grips on there as tight as possible... die grind 2 sides flat if you have to, and that should help you break it loose
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Senior Member Two Rings KevinA41.8T's Avatar
    Nov 30 2005
    CONNECTICUT
    Quote Originally Posted by AudiTechS4 View Post
    this is the best way I know of also. try this before you do more damage.
    2000 S4 IMOLA - CCW CLASSICS 18X9 18X10 - STASSIS TRACKSPORTS 700/800 - ASP DTS - STERN MOUNTS - 034 DP'S - ASP TRU DUAL - CUSTOM INTAKE/CATCH CAN - VAST METH - AEM WIDEBAND - RS4 INTERCOOLERS - JFONZ TUNED
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Quote Originally Posted by S4 Dan View Post
    That was one of the first things i tried and had no luck. The vice grips just cant hold on with that much tq being applied. The more i look at that bolt, the more i think they used JB Weld as a thread locker. Ive been working on cars for around 10yrs now and ive never seen anything like this.
    2014 Fiat 500 Sport
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Quote Originally Posted by KevinA41.8T View Post
    I dont think i can do more damage. The bolts are completely fubar'd and im going to pick some new ones up in a little bit. If i cant get it off im just going to take the air hammer to it and if i fuck up the driveshaft then i just wont get my $100 core charge, but atleast ill have the new one on there and be back on the road.
    Im going to try hammering a socket on and see if that does the trick, but im pretty skeptical because my bolt extractors basically stripped down the outside if the bolt.
    2014 Fiat 500 Sport
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    im glad i got my car all toghether without issues like this i still had a big scare
    good luck on gettin it worked out.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Well it seems like whenever yours is down, mine is down right behind it. So im hoping that you getting your car back on the road will bring some good luck my way lol.
    Hows your car running now? Is the oil leak completely gone?
    2014 Fiat 500 Sport
    Feb 28 2007
    chicagoland
    yes sir its runnign good .. just a CEL for my cats cause i took my defouler out on my pass side downpipe and it was all stripped so i need to get a new one to get rid of the code.
    just breakni in the clutch and making sure no more issues come up.. she pulls hard and is hittin 23psi on spike holding 20..
    needless to say im happy about it and can not wait to run my 104 program
    Nogaro 01 s4
    620whp 93octane
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Hell yea...congrats man. Im hoping everything goes good with mine today. Situations like this make me realize how much i love the simplicity and amazing engineering of a Honda though lol
    2014 Fiat 500 Sport
    Feb 28 2007
    chicagoland
    lol its not the amazing engineering or simplicity
    its just with a honda you coudl care less if your missing 4 bolts on your trans.. or 15 clips holding in your interior.
    thats the thing i miss the least is the absolute rattle box junk your driving when you drive a modded honda
    Nogaro 01 s4
    620whp 93octane
    Dec 06 2007
    Calgary, AB, Canada
    If you absolutely can't get the bolts out, I would just cut the heads off, pull off the axle, and then use a vice grips to try and turn the bolt shafts out once there's no torque on them.
    Feb 28 2007
    chicagoland
    before you do that.. cut the sides of the bolts so you haev square sides and try with an open end
    Nogaro 01 s4
    620whp 93octane
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Im probably gonna end up breaking or cutting the heads off the bolt...most likely breaking because its hard to get a die grinder or air saw up in there. Id rather cut them but i could only get a little over half way through before i run out of room with the die grinder, so i might cut half way through and break the rest off with the air hammer. I just got back from getting new bolts and some coolant from Audi so im gonna go out there and mess with it some. Those ******s charged me $70 for 12 bolts and a gallon of g12!
    2014 Fiat 500 Sport
    Dec 06 2007
    Calgary, AB, Canada
    That's a raping.
    Feb 28 2007
    chicagoland
    yea i deal with the same shit.
    49 dollars for 2 quarts of powersteering fluid
    no lube.
    Nogaro 01 s4
    620whp 93octane
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    I mean it really is ridiculous. $41 for 12 bolts and $24 for a gallon of of coolant...i laughed in the dudes face when he told me the price. Unfortunately, they basically had me by the balls since i couldnt get either of these anywhere else. There were 2 brand new rs4's and an r8 up there, so atleast i had something to keep me entertained for the 20 minutes it took the guy to find the bolts lol.
    Anyway, i finally got all the bolts out. I had to cut the heads off and pull the driveshaft then i was able to get 2 more bolts(which were now studs) out with alot of heat and vice grips, but the other 3 wouldnt budge. I ended up having to weld nuts on the end of the studs so i could break them loose with a breaker bar. I wish i had a camera so i could show you guys the insane amount of "thread locker" that they put on those little bastards. The whole bolt was literally covered in the stuff. As soon as i got them all out it started raining again, so i just gave up for the night. If everything goes right shell be back on the road tomorrow.
    Now its time to get sloppy drunk with a few friends and some decently hot chicks(after a few drinks anyway). Theres no better way to blow off some steam than some good beer and the company of a few loose skanks lol.
    2014 Fiat 500 Sport
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    just pound away on the skanks that always works for me
    Established Member Two Rings Moe's Avatar
    Jan 20 2007
    2000 S4
    Your Mom's house
    No threadlocker though.
    MTM chip, 5 bar fpr, 710Ns, H&R/Eibach set up, 034 street mounts, poly snub, piggies, suitcase mod, and oh yeah, K04s and a RS4 clutch.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Well i finally got her back together and running. Its been so long since ive driven it that i almost forgot what it was like. I havent gotten on it yet because im still breaking in the clutch, but she is boosting correctly and i dont have any codes....but most important is that damn shaking is gone. I still have some things to fix, but im just loving the fact that shes back on the road. The only thing thats really irritating me is that the pasenger side of the car is 3/16" higher than the drivers side. I guess the vogtlands didnt settle the same since it was parked in my backyard on very uneven ground. Hopefully itll settle a little more and even out...if not then ill just have to get those ecs(i think thats who makes them) coilovers that go over bilsteins.
    Im about to order some spacers, rs4 grill, and m3 spoiler...and im getting it tinted asap. Im glad i can actually spend money on performance/cosmetic parts now instead of buying stock parts to fix it lol.
    2014 Fiat 500 Sport
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    When I pulled my engine I broke six craftsman 6mm allen sockets getting those bastards out.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    It hapened to me the first time i removed the drive shaft on my car. I had to use a small pipe wrench, which is about 6'' long, and was able to grasp the allen head with it. Then i use a hammer to hit on the pipe wrench to loose the bolt. that was not easy. Had to replaced the bolt.
