    Active Member One Ring A4now's Avatar
    Jan 03 2007
    OH
    Question Flashing "INSP" reset??
    Can any body tell me how to reset the flashing "INSP" reminder? It's flashing for an oil change, which I just completed. I've watched my mechanic reset it before, but it's not coming to me. Thanks.
    A4Now
    '03 A4 QUATTRO 3.0
    Sep 23 2007
    Re: Flashing "INSP" reset??
    http://www.audiworld.com/tech/elec26.shtml
    if it says change oil then this will work if it says service inspect you need a vag to reset that
    Apr 22 2007
    Riverbank, Ca
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    It tells you in the owners manual if you have one in the odometer section I believe.
    Hold down the odometer button as you turn the ignition on then pull the clock button out (just like an oil change reset) once that has reset press the odometer button again (it should switch then to insp on the screen) and once again pull the clock button.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    It is in the B5 FAQ too. I just referenced it a day or two ago.
    Jim
    I Do Werk.
