GUYS!!!!! he didn't didn't even look into it enough to buy the right turbo...... do you REALLY think he is goign to be able to disassemble a turbo and successfully get it reassembled and properly balanced (no offense Beesix)? maybe oyu ment for him to take it somewhere to have it done. as far as i am concerned, i'll rip just about anything on my car apart including the tiptronic transmission without to much though but the two turbos that i did take apart required a real shop to rebuild after i touched them because i messed them up. telling him to swap the turbines is not good advice unless he has done it before. Not to mention, the K03 housing is DIFFERENT, the turbines are different size and the K03 would need to be machined out to fit!
Beesix, Face the fact that you F-ed up and just sell the one you got because it is the wrong part for your car and get the right one. If you try to make this one work your only going to dig yourself deeper into the mess and create issues that your going to be fighting until the car dies. If you had done your research before pulling the trigger you would have seen that the K04 won't give you too much more power and it would have been best just to skip it all together and save your money for a real upgrade.
Remember your car won't run for crap after you install the turbo until you get a K04 flahs for it. Does anyone know if Revo makes a K04 file? i have never heard of one (S1 is just the flash, S2 is EFIs, and S3 is BT), kinda doubt they don't have one or can't make a custom for you though, but you will need a re flash one way or the other. I also don't' see an FMIC in your mod list, that would be a very good idea to have.
Sorry if this post comes across harsh but you should have researched this before throwing your money away.
