Results 1 to 9 of 9
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Exclamation Something's wrong with my coolant!!!
    Started cleaning the engine bay yesterday and noticed this (pics below). The tank isn't empty in the first pics, I tilted it so I could get a shot of the crud, what is it? What causes this and how do I fix it?
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: Something's wrong with my coolant!!!
    Looks like oil.
    Could be a leaky headgasket.
    Stage 3+ RS6's
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    or a bad oil cooler.
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    oil in the coolant could be from bad oil cooler or bad head gasket. How old is the coolant in the car.
    Dec 08 2006
    Jersey
    I just found out it could also be from a bad oil cooler. The coolant is pretty old, some of it may be from the day I bought the car because I doubt Audi ever flushed it and I only changed it when i changed my timing belt a little over a year ago. I talked to my friend that works at Audi and he told me it's very common in the 1.8T to have off color coolant after a while so I'm not in panic anymore.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    first...why is your coolant clear...second that looks like rust. if you were using water as coolant it will start rusting your engine.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by BARRY View Post
    lol o yea? whered you get that info?
    Hey man, try the oil cooler, if not its the headgasket. Shoot me a PM I can get both of those done for you
    - Clint
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Water is a bad chemical for cooling, it has relatively low heat capacity. That's why we use anti-freeze or similar. I always heard that pure water can promote oxidation (rusting), but it looks more like an oil than rust. Just my worthless $0.02
    Dec 08 2006
    Jersey
    Update: I didn't use water, I used 50/50 of g12 and hose water which I know was a bad idea. So I came home from work today and flushed all the coolant, the pictures don't show the color right at all. The stuff in there is more orange than anything else, anyway, I flushed the coolant and replaced it with 50/50/ g12 and distilled water. If it turns colors soon then I will suspect the oil cooler because I don't have any other signs of a bad head gasket.
    Thanks for the help guys
