Results 1 to 16 of 16
    Senior Member Two Rings Asix's Avatar
    Jan 25 2008
    Audi S5
    Bellevue, WA
    DIY for Daytime Running Lights for C5 A6
    Hey guys. Has anybody done a DRL mod for their C5 A6?
    What do i need and where do I get it? I looked in my headlight housing and I have a little piece that looks like I can pop out a hole toward the top of the hi-beam housing portion.
    Thanks in advance guys!
    Senior Member Three Rings 11move's Avatar
    Nov 25 2007
    Re: DIY for Daytime Running Lights for C5 A6
    Get a vag com and change the coding from USA to Canada and you have DRL's :) at least it is how it is for my A4
    Jan 25 2008
    Audi S5
    Bellevue, WA
    Oh snap...now that sure would save time and money!
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    A4 and A6 codes are different.. good luck with it.. i got the Ebay Vagcom wire and still haven't trouble changing anything..
    Nov 25 2007
    Quote Originally Posted by 04A6SLine View Post
    Not in this case....
    Go to Instrument Cluster Module 17
    In there you will have this xx2xx: Country
    Change the two to a 3 and you should be DRL Enabled :)
    ??xxx: Options
    +01 = Larger Fuel Tank (80 liters for 8-Cylinder Quattro and S6)
    +02 = Seatbelt Warning active
    +04 = Tires for Allroad (MY 2002+)
    +16 = Navigation System (w/o CAN Connection)
    xx?xx: Country
    0 = Germany
    1 = Rest of World (Left Hand Drive)
    2 = USA
    3 = Canada
    4 = Great Britain
    5 = Japan (Left Hand Drive)
    6 = Arabian States
    7 = Australia and New Zealand
    8 = Rest of World (Right Hand Drive)
    9 = Japan (Right Hand Drive)
    xxx??: Engine
    40 = 4-Cylinder Diesel
    42 = 4-Cylinder Gasoline
    44 = 4-Cylinder Gasoline Turbo
    60 = 6-Cylinder Diesel
    62 = 6-Cylinder Gasoline
    64 = 6-Cylinder Gasoline Turbo
    83 = 8-Cylinder Gasoline
    Jan 25 2008
    Audi S5
    Bellevue, WA
    wow nice post!!!! thanks man!!!
    Mar 16 2010
    Pittsburgh, PA
    Re:
    Very interesting, Asix, did this method work for you, and do you have factory HIDs" Also what year is your A6?
    Thanks,
    Brett
    Veteran Member Three Rings BostonDriver's Avatar
    Sep 22 2004
    Massachusetts
    VAG COM does not work for C5 A6 running lights. Had to be hardwired.
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    That little hole is for city lights used in Europe, you can re-drill the hole, get city light harness with bulb plug from VW Golf MKIV, one wire is for ground and other connect to your DRL harness plug, you can have your city lights as DRL
    however you will need to do some rewiring so the only city light is drl and rest not if this is what you are looking for
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Veteran Member Three Rings Tamas's Avatar
    Jul 27 2009
    '05 allroad 2.7t 6MT, APR Stage I
    Toronto Ontario Canada -eh?
    Quote Originally Posted by audifirst View Post
    yes please
    Mar 16 2010
    Pittsburgh, PA
    Thanks guys,
    I was hoping that the vagcom could simply activate the low beam as a drl (easily, like the key fob remote window up/down setting), but I suspected that the wiring would prevent that. I've heard of the drill out city light mod, and to be honest I don't like playing with the factory wiring, but thanks again.
    Jun 03 2011
    San Luis Obispo, California
    Howdy,
    Do you happen to have instructions or a link to hardwire a C5 A6 to use the fogs as DRL? I have already done the fog parking light bridge mod, but I have had a couple dead batteries after leaving the light switch on. I'd just like the fog and park lights to turn off with the ignition...?
    Thanks
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    Quote Originally Posted by Blange05 View Post
    Thanks guys,
    CDN DRL's are the fog lights (plus markers), not the low beams. My guess is that the VAG-COM mod does work but is being blocked (for lack of a better word) by the fact that fog light function is tied to the low beams in the US model cars.
    Senior Member Three Rings Batcave's Avatar
    Feb 08 2011
    Pacific Northwest
    I have a US C5 A6 that was imported into Canada and I have the fog log - DRL mod. I'm not sure how it was done, but it would probably be wiring around the light switch and/or ignition. From the ignition, you could connect a harness to the wire from the switch that illuminates the fogs. That's what I would do.
    However, it looks like some others have done this on other models...
    http://www.audizine.com/forum/showth...t-with-Fog-Mod
    Mar 01 2004
    1984 VW Rabbit GTI, 2008 Mk V GTI
    Greensboro, NC
    Quote Originally Posted by Thunderhammer View Post
    Howdy,
    Thanks
    I'm looking to do this VAG COM modification (fog parking light bridge mod) to my '05 Allroad. Do you have the instructions to do it? I've been searching but cannot find the steps for the C5 A6 and it's driving me nuts.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by scottyvee View Post
    Instructions:
    http://allroadfaq.com/downloads/mods/foglight_mod.pdf
    I actually drilled my high beam reflector, and installed Cree 22 watt H1 LED with small projector lens there.
    Connected with this relay:
    http://www.ebay.com/itm/360394205189
