Results 1 to 14 of 14
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    Boost falling at 4500rpms. TIP?
    So my friends car has apr1+ and it boosts right up normal peak 19psi holds 18psi. Then no matter what gear around 4500rpm the boost just starts falling down. It gets to about 10psi by redline in 3rd.
    Tip collapsing?
    Anyone know what this is.
    The Car.
    2004 A4 18.t AMB 6spd Quattro
    Apr 1+. Some unknown brand exhaust after downpipe. Billet DV with heavyist spring Factory everything else.
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    Re: Boost falling at 4500rpms. TIP?
    Possibly the shitty stock plastic diverter valve is leaking and is not holding boost.
    It could be a number of things, honestly.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by mister_tu View Post
    Most likely this is the answer
    Apr 07 2008
    Fort Collins, CO
    ok forgot one. has aftermarket DV with heavyist spring
    May 24 2007
    Southern California
    thats a stock turbo for ya.
    Kyle
    2.0L Revo GTRS Eliminator
    Apr 07 2008
    Fort Collins, CO
    I was wondering that. But my friend has a gti with 1.8t and apr chip and it cranks out 18 all the way through.
    I don't think it is just the little turbo.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by A4natomical View Post
    ... GTI turbos are a bit different than ours and also the engine isn't working as hard to get the car moving with the FWD... that may not matter but its a guess
    - Clint
    May 24 2007
    Southern California
    didnt know it was a gti. my badd. alright ill shut up.
    Kyle
    Apr 07 2008
    Fort Collins, CO
    No the problem is with the a4. I was comparing to a gti.
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    I think the 180hp GTIs have the K03s just like us. The TIP collapsing gives some surge, but I wouldn't think it would cause an "underboost" condition all the way to the end.
    Also, the peak psi should probably be higher than 19 for a 1+ right? Closer to 21 ?
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Apr 07 2008
    Fort Collins, CO
    Yes as far as I know same turbo same motor. I know the a4 is heavier but I'm not talking about a loss of power at the end I'm talking about a loss of 10 psi. Something is up.
    Anyone running apr1+?
    gtimart you are right FXko3 is same thing. What boost are you running? Does it ever let off?
    Sep 13 2007
    Quebec, Canada
    I don't remember my only log I did a few months ago. Boost certainly falls after 4500-5000rpms, that small K03s cannot hold 18psi all the way. I think it will peak around 19.x psi (24xx mbar IIRC)? I think my comment about 21psi was wrong in my earlier post.
    I guess it goes down to around 13-14 psi at redline normally.
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    i have apr stage 1 with forge 007 (yellow spring) and i peak at about 19psi and then it falls to about 14 psi around 5000rpm. i believe all k03's drop pressure after 4500rpm. its just the way the car is. on stock file the car runs about 7 psi after full spool and when its in high rpm it wont reach full boost. this is in my personal experience and a little bit of what ive heard. i dont know if i'm fully correct so i'm open to any response to this post.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Feb 17 2005
    Sarasota, FL
    No way any K03, VW or Audi, is holding more than 14-15psi past 4500. 12-13psi 5k till redline is 100% normal
