Results 1 to 4 of 4
    Deactivated Four Rings
    Nov 19 2006
    MMM
    God dammit - ABS problem after control arms
    So I torqued down the axle bolts with the ABS sensor in and now I have two ABS Wheel Speed Sensor codes. I just cleared them and now only the left is coming back (Open or Short to B+). I think one of them may have been a left-over code from when I started the car with the right side unplugged.
    Gonna pull out the left sensor now. If I go to the VW dealership and ask for an ABS wheel speed sensor for a 99 Passat GLS is it the same part?
    Nov 19 2006
    MMM
    Re: God dammit - ABS problem after control arms
    Turns out both the sensors at least are broke. What else should I check?
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    SO- what did God do to your wheel sensors?
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Nov 19 2006
    MMM
    Shokan has sensors for $75 each, not too bad. Think I'm gonna order two of these and have them in on Monday. What other parts should I check for damage?
