Results 1 to 15 of 15
    Senior Member Three Rings Just Quaff's Avatar
    May 11 2007
    01 A4 1.8TQM
    Code thrown following timing belt
    Hey, I just got finished doing the timing belt on my car. Everything went really well and the car runs and sounds fine. But for some reason I am threw a CEL right after doing the belt. Its late right now and haven't had a chance to VAG it, but I was wondering if anyone had any thoughts as to what it might be. Im out of ideas. Probably something stupid again like my damn O2 sensor freaking out about my test pipe haha.
    18" VMR RS4's Hyper Black | Samco Diverter Valve | ATP 3" Test Pipe
    REVO chipped | Koni Adjustable Coilovers | 19mm Neuspeed Rear Sway
    AWE Vent Pod Boost Gauge | Seat Cupra R Front Lip | Painted Lowers | S4 Side Skirts
    2.5" Custom Cat-back Exhaust to Magnaflow 12158 | 6000K HID's
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Code thrown following timing belt
    I know exactly what it is...you must be low on timing belt lubricant fluid. Vag it son.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Dec 03 2005
    2 pedals 1FG
    connecticut
    How can you post up that you have a code after your TB job but not tell us what the code is?
    Fail.
    Get that code for us to help you out.
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    Fail.
    lol... "Hey guys, I have a CEL what is it?"
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    It is a light on the dashboard that has the shape of an engine but that's not important right now.
    -Doug
    Jan 21 2006
    6MT BT Avant Ti
    RI
    CEL in Polish means Target or Goal
    May 11 2007
    01 A4 1.8TQM
    Sorry guys. I told you i would get one posted today. Bad news though. I threw P0011 which apparently is incorrect camshaft timing. But I know that I didn't miss a tooth because I marked the bottom crank as well and did one full turn and both the top and bottom shafts matched perfectly. The car seems to run perfectly fine, however the idle sounds unsteady but only from the exhaust. The engine sounds fine and the idle on the tach doesn't move at all. Any thoughts?
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    A simple search revealed this thread: http://www.audizine.com/forum/showth...ighlight=P0011 worth the read.
    Good luck.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    You should really verify how much it is off. You can easily do it by dropping the belly pan and cranking the motor until the crank is lined up with its mark. Then pull the TB cover and see how many teeth you are off on the cam. You should take the front end off again or at least get it into the service position to pull the belt and realign everything. I was able to correct the timing that was off almost 3 teeth by just putting in it service position. Then I pulled the belt off the cam. Adjusted cam, and pulled the TB back on the cam with a few thin/short flat head screw drivers.
    The crank looked like this...
    When the cam was lined up...
    I know that is a backwards pic of how it should be. With the Crank lined up that equaled three teeth off on the Cam.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    May 11 2007
    01 A4 1.8TQM
    Quote Originally Posted by Matt@JHM View Post
    Good luck.
    Thanks man, I guess I could double check again.... I was pretty sure it lined up but maybe I smoked a few too many bowls that night.
    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    Quote Originally Posted by Just Quaff View Post
    ....But I know that I didn't miss a tooth because I marked the bottom crank as well and did one full turn and both the top and bottom shafts matched perfectly....
    doesn't necessarily mean you are correctly timed. on my aeb the timing mark for the camshaft pulley is not exactly perfect, so the pulley sits slightly off. if you're not careful or paying attention you can rotate the camshaft pulley in the wrong direction, be off one tooth, and everything will appear to line up.
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    May 11 2007
    01 A4 1.8TQM
    Quote Originally Posted by b5v6 View Post
    I think i just might be off a tooth on the lower crank. But its weird. My car sounds fine and runs better than ever. I think it is actually pulling harder and smoother then it did before which is kind of weird. The idle thing isn't even an issue anymore. But yeah, need to yank her apart again.
    May 11 2007
    01 A4 1.8TQM
    Ok guys, so I busted into it again yesterday to see if I could figure out if the damn thing was not aligned. So, it turned out that it was a tooth off when we opened it up. Well anyway, my concern is that I know for a fact that the car is aligned (that being that the mark on the cam and the mark I made on the crank are both aligned) but for some reason I am still throwing the same code. It is my understanding that the code can mean that my cam position sensor is out. Any other opinions on this? I am trying to figure it out before I go and buy the damn sensor which is like 100 bucks... I really just want to know if its the sensor that is causing the code to be thrown?
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Next time, count teeth on the belt... Mark each mark on the cam and crank sprocket and on the belt... Make the same marks on the new belt and when you install them, make sure the belt matches the marks on the cam/crank...
    ΜΟΛΩΝ ΛΑΒΕ
    May 11 2007
    01 A4 1.8TQM
    Quote Originally Posted by Ewok_Fetus View Post
    I think i mentioned that I did that above?? But yeah, I marked everything, and everything is matching up now. But the ECU still is throwing the same code at me despite this. I really am wondering if its this cam positioning sensor.
