Results 1 to 8 of 8
    Registered Member Two Rings phoenixr2's Avatar
    Dec 15 2006
    03 Honda RC51 03 Audi A4 1.8TQ
    coolant flange replacement, question
    Just trying to research to see if I am in for any surprises. Why do people recommend replacing the ECT sensor, what is the reasoning for this?
    thanks!
    Aug 14 2007
    2002 Dodge Dakoto 4.7L & a 1990 Honda Accord that won't die
    Bellevue, WA
    Re: coolant flange replacement, question
    The sensor's have been known to go bad for others and is not an expensive item to purchase. If you are DIY'ing on the coolant flange, it's just easy to replace since you have everything out of the way anyway to get to the flange. I just did my flange last weekend at 76K and did replace my sensor also -- will keep the original as a backup.
    Clicky to AW post
    Veteran Member Three Rings dino's Avatar
    May 24 2004
    2003 Audi A4 1.8T 5MTQ, 2015 Audi Q7 Sline 3.0TQ
    This tool is a lifesaver. Use it to remove the clamps. Wear eye protection.
    http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
    This will help you see what you're doing. You'll feel blind without it.
    http://www.sears.com/shc/s/p_10153_12605_00941603000P
    Good luck... this DIY was a major PITA.
    ~> dino
    2003 A4 1.8T 5MTQ - Brilliant Black on Ebony
    | Bose | Cold | Premium | Sport | Xenon |
    | Visor | A4 Rubber Mats | Tint | Aero Kit | Ross-Tech KEY-USB | V1 | Podi | Euro Knob |
    | APR K04/Snub | GFB Hybrid | TT225 Injectors | AMS SS | RaceTec FMIC | Hayden PSC |
    | B5 S4 Front Brakes | Hawk HPS | ECS Lines | Motul RBF 600 | RS4 RSB | PSI TP |
    Items for Sale
    Aug 14 2007
    Bellevue, WA
    Very much agree about the clamp plier and mirror shown. I already had the pliers, very necessary on the two squeeze clamps for the rubber coolant line -- get the one shown. Actually had to stop in the middle of the job to go buy one of those mirrors -- big help to see how to get the bottom bolt/nut off the coolant flange. I also had to stop and go buy gear rachet wrench set along with the socket set I show in my AW post to get the top bolt off the flange -- very small clearance called for a very low profile socket and rachet setup. Make sure you have some extra zip ties for the ones you cut away, and replacement hose clamps for the vacuum lines that you disconnect.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    +1
    I couldnt imagine doing this job with that tool (1st pic)
    -Sami-
    May 24 2004
    a pic from the small damage on my coolant flange. it's at 12 o'clock.
    hook me up w/ some reps.
    ~> dino
    Items for Sale
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That tool is a godsend. I did this job with the SAI in place and without that hose clamp tool. What a pain in the ass. I did this job when I put my new engine in and the SAI was gone. What a simple job. The SAI system makes this task 10x more difficult than it should really be.
    -Doug
    Dec 15 2006
    am I looking for this one
    Original Equipment Supplier - Coolant Temperture Sensor ES#8268
    2-pin black sensor for water temperture
    or this
    Meyle - Coolant Temperature Sensor With O-Ring ES#8485
    Revised Green 4 pin sensor. With square/round connector. Replaces faulty black style. learn more
