Results 1 to 40 of 42
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    Audi B6 1.8T Chip
    I am thinking about chipping my Audi B6 1.8T. What should I get? How much hp and ft lbs will I add?
    Also want to up grade my wheels to 18 x 8 RS4 35mm offset. 235/40/18. How will this set up work? Should I expect any rubbing? My car is stock.
    Thanks
    Sam
    B6 1.8T
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: Audi B6 1.8T Chip
    1) if you're going stage1 apr,giac,revo, doesn't matter its all the same.
    2) yes those will fit. Running exactly the same on mine and lowered no rub
    Markham huh? along hwy7/richmond hill i bet.
    CT4952
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    I called this shop (http://www.euautowerks.com/) and they are saying they use these guys (http://www.upsolutetoronto.com/) to do all their chips.
    Looks all good to me. But I've just started doing the research.
    Any thoughts?
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    i've heard upsolute is alright sure how their software is..
    Search GIAC/APR/REVO you'll find a wealth of information.
    my opinion ECU. don't cheap out on it.
    CT4952
    Veteran Member Four Rings headshok2002's Avatar
    Jan 22 2005
    2010 VW Passat Highline wagon
    Sudbury, ON
    I'm sure Upsolute is good... I'd consider the big names because they have injector files, though... something you can upgrade to later if you want, for little cost. Upsolute does not have a stage 1+ (that I'm aware of), so you'd be missing out on that option.
    I know with APR, stage 1 makes 209 hp and 236 ft/lbs... while adding the 386cc injectors and flashing stage 1+ makes 229hp and 271 ft/lbs. Definitely a worthwhile upgrade... and those figures are on 91 octane, while 93 octane makes more power again (not much).
    GIAC and Revo only flashes 91 if I recall correctly.
    I have APR 1+ in 91 and 93, though I've only ever used 91... I'd say that I am happy with it, but it is very smooth. I think GIAC 'feels' faster... but I've no idea as to which one is actually faster, on a track. I think GIAC comes on harder, and perhaps dies off quicker... while APR is much smoother. It's all a personal preference thing... I don't think I'd care if I had GIAC 1+ (there injector flash isn't called 1+... it's fx or something) vs APR 1+. Just do the research, you'll find plenty of opinions (people saying their chip is the best).
    Good luck!
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    I think I am going to go with the GIAC Stage 1+ at Pfaff.
    Wondering if I should go 19's instead of 18's. Am I pushing it? I just want to be able to bolt on the new set of wheels, get an alignment and be on my way. Don't want to have to make them fit.
    Any thoughts on that?
    Thanks
    Sam
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    18" are good enough. More tire options less expensive then 19" unless you got a lot of $ to spend to be baller.
    CT4952
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Quote Originally Posted by headshok2002 View Post
    Good luck!
    REVO with the Select Plus switch allows you to adjust the tune settings (Boost, Fuel, Timing) for anything in the range 91-100 Octane.
    Jan 22 2005
    Sudbury, ON
    Quote Originally Posted by Siggiepop View Post
    I feel that on the B6, 19's are the way to go... Considering the B6 (ultrasport) had 18's... 19's are a +1 setup, which is always tasteful. 19" tires are really not that expensive at all anymore, and on a B6, they just look perfect. 20's start to get a little big, although I think the right wheel in 20" would look great on a B6 (think BBS LM).
    You won't need an alignment after getting wheels, either... It shouldn't change anything. If you lower, it's always a good idea to get aligned (something I've had on my to-do list for the past several months, haha).
    So yeah, 19" wheels in 5x112 with about a 35mm offset is what you're after. You can use any offset from 32 - 42 on a B6, provided the wheel isn't any wider than 8.5". If you don't get offset, just understand that a 32 will stick out 10mm further than a 42.
    Cheers!
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Yeah some argue that but 18" are lighter no matter what hehe
    CT4952
    Jan 22 2005
    Sudbury, ON
    Haha, true enough... but as most people have cheap cast wheels, they're all heavy anyhow. 20" forged 2/3 pc is probably lighter than an 18" cast, most of the time.
    I have a 19" LM replica... I don't really care about weight, I don't drive my car hard at all.
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    What size tires do you have on your 19's? Did you have to make any mods to not get any rubbing?
    Thanks
    Sam
    Jan 22 2005
    Sudbury, ON
    235 35 19 is the proper size for a B6 A4, and I did not need any modification at all to avoid rubbing. I've lowered the car with Neuspeed Sport springs, and am running 235/35/19 Nitto INVO tires on 8.5" wheels with ET35. I've never rubbed with this car... ever.
    My b5 A4 rubbed all the bloody time, though. I've been really happy with how the B6 responded to lowering and wheels (barely noticed a difference in harshness, and I went +2 from a 17" stock sport setup).
    The suspension made the car a bit more rough, though... obviously. Bilstein sports are to blame, I'm sure. I love it though!
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    running 18" with stasis and its perfect.
    CT4952
    Jan 22 2005
    Sudbury, ON
    Yeah, wheel diameter makes no difference, if offset and width is the same. You'd just run 235/40/18, which would be the same size as the 19" counterpart.
    19's just look better on a b6. :)
    Veteran Member Four Rings BryanR's Avatar
    Sep 08 2004
    2003 Audi A4 1.8tqm Avant
    Ottawa
    I vote GIAC (chip is both 91 and 93) and 19's
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    These are the 18's i am looking at:
    http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
    and these are the 19's:
    If I can find a similar style to either of these with the hyper silver finish i am going to go with 19's. But I don't want chrome.
    Any ideas where i can get what i am looking for?
    Jan 22 2005
    Sudbury, ON
    18's you posted are common, but many people like them. I had them on my previous car for a while (04 black USP) and I preferred the stock 18" wheels it came with (b5 RS4 style).
    The 19's you posted... they look like BMW M3 wheels... in chrome. Chrome isn't really... uhh... liked... around here. :)
    To each his own, though!
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    I don't want chrome either. I really like the hyper silver finish.
    Jan 22 2005
    Sudbury, ON
    Yeah... avoid chrome for sure. Heavy... ugly... just no good.
    The m3 wheels would be weird, too... Hrm.
    Do you plan on lowering the car, or no?
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    No I do not plan on lowering the car. Don't want to sink a lot of money into it. Just want it to look a little different than stock.
    Jan 22 2005
    Sudbury, ON
    Is your car sport or ultrasport?
    If not... It might not look good with any wheels, without a drop.
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    It's a sport.
    Jan 22 2005
    Sudbury, ON
    Right on. I'd do the "OEM+" as it's been called... just go 19" RS4 or something. It'll be clean, and won't look too goofy on stock sport.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Just go for spinners.
    And an exhaust.....I think this one is a borla right?
    Jan 22 2005
    Sudbury, ON
    Quote Originally Posted by audipotential View Post
    Me likey. Too bad the damned cutouts on the B6 lower bumper wouldn't fit. I wonder if Borla makes that in a 3.5" diameter?
    Sep 24 2007
    Woodbridge, Ontario
    You have to bow down to the exhaust.
    If youre not willing to cut holes in the bumper then you must bow down to this
    Jul 06 2008
    red rock or new braunfels
    so will the tt 225 injectors work for stage 1+ chip then?
    and i wish i could find some M6 wheels in 5X112
    Jan 22 2005
    Sudbury, ON
    The TT 225's will work -- they are pretty much required... You can use a generic 380cc, but APR designed 1+ around the 386cc TT225 injectors.
    Jul 06 2008
    thanks, thats what i wanted to know
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Quote Originally Posted by red_rock_beetle View Post
    There's an APR sale going on now, but I'm not sure if it's at all APR dealers or only the new location they opened up.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Three Rings burns420's Avatar
    Oct 20 2007
    Quote Originally Posted by WiZZLa View Post
    What is the sale and where did you see it?
    Jul 10 2007
    trunk
    Quote Originally Posted by burns420 View Post
    http://www.audizine.com/forum/showthread.php?t=232781
    APR ECU Upgrades
    **Fully Loaded for the Price of a Single Program (Save $604!) or $100 off of a Single Program(1.8T, 2.7T, 2.0T) or 10% off of a Fully Loaded Suite(Porsche, RS6, VR6, 4.2L)**
    Stage 0 minus - .5
    Veteran Member Three Rings yb28's Avatar
    Mar 06 2013
    2017 B9 A4 2.0T Quattro DSG , 2017 Q5 2.0T Quattro TIP
    Toronto, ON
    is this an ontario thread?!
    just picked up my 03 1.8t yesterday.....good a bunch of things to fix before upgrading, but will add a boost gauge to see if the DV needs to be changed...then i might save up for revo, but I dont want to run into any reliability issues since the car is old and has 173k kms on it..., wanna lower it a bit and go with some 18 or 19 rs4 rims!
    ive heard revo is good...after doing some search..many people are happy with revo stage 1 tune
    Sep 08 2004
    Ottawa
    Unitronic, GIAC or APR before Revo imho. Usually go with the best local support. Cheers
    Mar 17 2012
    Toront, On
    You can flash APR DEMO and run for 6 hours. Just if you want to test out their program! =D
    H&R Radiator is a authorized installer.
    On the side note, ill go unitronic
    Active Member Two Rings acid16v's Avatar
    Nov 21 2012
    87 16v Scirocco, 05 A4Q 1.8T
    Unitronic
    Sep 08 2004
    Ottawa
    Just realizing this thread is from 2008....
    Nov 21 2012
    I have the stage 1 (not 1+) Unitronic. Is there any increase in performance if I replaced my injectors with the TT225's? If so, does anyone here know the Audi OE part# ?
    Thanks in advanced
    Mar 06 2013
    Toronto, ON
    lol yup I love reviving posts :p
    anyways little update, did all the maintenance stuff, got a forge splitter (which failed after being on 1 week....) took it out and repaired it myself. also installed a boost gauge..
    just ordered some caliper decals for my b5 s4 hp2s :)
    have an appointment with JRP this fri to get revo but then i'm still not sure which tune to get -.-
    also one more question...people say stage 1 tune doesnt really matter, what about reliability issues on the 1.8 engine? its putting out almost twice the boost from stock so i understand that i'll be putting more stress on components but has any body expeirenced any problems ?
