Results 1 to 7 of 7
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    Coolant Warning on DIS
    Hi Guys,
    Had the clutch change finished yesterday.
    But now the coolant warning comes on. My mechanic told me he checked the coolant lines/system and believes it is a faulty sensor and should be fine.
    After I got home I saw the temps looked exactly the same as before I delivered the car. Coolant halfway (90 Celsius) and oil just below a notch over minimum (thermostat problem I believe). But the point is every reading is the same as before.
    Coolant level is fine, pressure is there. The electronic fan turns on (the one on the right), not the left one (which I believe kicks in at different point)
    I left it for 10hours in a pretty cold ambient and came back. I put the key in on On position (im assuming that is the position that lets u use the radio and AC and lights up the dash etc etc). When I put the key in the ON position the coolant warning came up again. All the temperatures were minimum and the coolant level is still above MIN.
    No Idea whats going on...?
    I'm thinking:
    1. I did believe I had a thermostat problem before (overcooling & poor mileage) but now related to overheating?
    2. Coolant temp sender. Heard of this failing/not secure, can't locate it.
    3. Bubble/air in the system.... but still seems pressurized
    4. Water pump. Doubt it, was changed only 17k miles ago. Not sure how to check
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Coolant Warning on DIS
    Did you check the plug under the coolant tank? If it is uplugged you will get a coolant warning light. MY guess is that he unplugged it to get the tank out of the way for the clutch install but forgot to plug it back in before he mounted it down with the 3 screws.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    ^Exacarry^
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Wow, that is a good one because I always forget to plug that stupid plug in every time I remove the resevoir.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Mar 01 2008
    '12 1M
    Sydney, AU
    Ok I just had a look under the tank I see a plastic insert/hole and I guess that is where the plug goes.
    I see nothing loose though.
    Since it's on the way to work I will drop by to the workshop.
    I assume it is safe to drive if temps are ok or does that Plug influence anything else apart from diagnosis/readings.
    Jul 07 2004
    socal
    Quote Originally Posted by gmx View Post
    Yes it is fine to drive it like that. That sensor just lets you know when your coolant is too low.
    You can look for it yourself, just take the 3 screws out and pull the tank up/foward. Then just look for a loose plug that is about 6" long in that area.
    Veteran Member Four Rings boosteda4's Avatar
    Feb 28 2005
    B7 A4 | Camo 4Runner | LandRover LR3 | YamahaR6 | 71 Triumph Spitfire
    Merced, Ca
    This saved me! Thanks guys! Search FTW!!! I had the EXACT same thing happened to me... and i found this and checked and it was the problem =) what a stress reliever.
    LandRover LR3 | Audi A4 | Yamaha R6
