Results 1 to 15 of 15
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Quick bumper question...
    Which bumper has the most room behind it for an FMIC, the stoock USP, or the stock S4 bumper cover. I need to pick one and I am leaning towards the S4 (less expensive), but I have a FMIC and want to know which will clear it easier.
    No I do not want to go reiger, otte etc Thanks for all you input!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Quick bumper question...
    What kind of FMIC do you have? My AWE fit fine with very little trimming on the stock bumper.. well very little necessary trimming.. oops
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    I have a universal fit FMIC, but I had to space it away from the condenser about 35mm so my inlet and outlet connections would not hit the condenser.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    The rebar for the S4 is the same as the stock bumper so the distance between the condenser and bumper rebar won't change... I believe the USP bumper is a different rebar... but not sure.. or is the issue on the bottom?
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    The spacing I am looking ofr is below the rebar, I inquired and the S4 amd A4 use the same rebar, I had to mod the rebar anyway so that part is out of the way. The concern is the lower half of the bumper and the space, my wife's A4 is running a evolution FMIC which is smaller than mine in height so it was put up against the condenser, and with the stock bumper it is a tight fit. From pics I was able to find it would appear the S4 bumper may have more space in the lower.......
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I have an S4 bumper at the house, i'll take a look to see later to today.. or someone who has done the swap may chime in on additional space..
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Awsome, thanks!!
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    I think the USP bumper has a little more room at the bottom, whereas the S4 bumper curves a little back.
    Previous
    USP B6 A4
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    would you say both the USP and the S4 have more clearance than the stock A4 bumper?
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    I just put on a front s4 bumper, and i had a hell of alot more clearence for my inner cooler. I dont have pics right now but i have 2.5 inch piping and it give me alot more room. As for the usp im not sure.
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    awsome thanks for the info, did you find it was more room in the center as well as the sides (where the pipes run).
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Subscribed.. I've got a USP lower on the way. My Reiger bumper had to be cut quite a bit in order to fit around the couplers connecting to the core. Hoping the USP won't be quite the same.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Feb 20 2007
    ct
    I'll take some pics for you today, i still have to order some grills so i dont know if i can fit both fog light grills but I will try.
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    awsome, I think it is a useful thing to know, for those who want to either add a FMIC and keep a stockish look. I had the same problems with the reiger front, I hacked it up quite a bit and was not happy with the look, also the fit to the fender is always a little off looking. Besides you can keep the stock side skirts with the S4 bumper, whereas the reiger looks a little funny. i also think the s4 bumper will be more practical for the winter driving.
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Hey Phantome B6, I just noticed you are running the same FMIC as i am.
