Results 1 to 16 of 16
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Need opinions from all AWE SMIC owners with OEM S4 front bumpers, TIA.
    Please comment on their installation and their fitment. Do they fit perfectly or do they push out the bumper on the sides ? How would you rate their fitment on a scale of 1-10 with 10 being a perfect fit ? TIA.
    Dec 27 2006
    01 s4, 14 Q5 TDI
    Pasadena,Tx
    Re: Need opinions from all AWE SMIC owners with OEM S4 front bumpers, TIA.
    fitment 8.5/10....some cutting, pretty tight between ic and bumper support bracket.
    2021 Audi S4…AWE Tuning exhaust, ???
    Sold..AWE stage 3, AWE IC, vast stage 3 clutch, piggie pipes, vibrant exhaust, h&r co, 18" OZ Ultraleggera powdercoated high gloss black, JHM BBK Cayenne
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    some people have said that no cutting is required, i have mine waiting to be installed so this will be good info.
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    ^^ those people probably never installed one. cutting is required.
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by nizmosx View Post
    FWIU, cutting of the radiator support and fender is required, but not cutting of the bumper cover as in RS4 ICs.
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Bumper fits perfectly for me. Like said, you do have to cut the radiator support and fender, but not the bumper and nothing that makes it noticable. In fact, I was at a German car GTG over the weekend and everyone thought my car was stock. lol
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Jun 14 2007
    2000 S4
    Connecticut
    bumper fitment is 100%... there wasn't cutting.... only shaving down of the bumper support bracket on driver side.... i didnt do it though Greg (SSP TUNING) did, and he's done them before, made them fit perfect
    Veteran Member Four Rings SurferD's Avatar
    Apr 30 2007
    15 Forester XTT, 03-F150, 03-WRX, 71-240Z
    Orange, CT
    I just did this install yesterday!
    Yes the radiator support and the fender "wing" supports have to be cut. They don't tell you to but the right side fender support needs a trim too. Make sure you prime/paint it after. The radiator support is plastic so no worries there. I used a sawzall with a metal cutting blade and it went easily. Just look for wires before you cut. While fitting the bumper, I also had to trim the inner reinforcement of the left side bumper to clear the new duct. I also ran into a snag that AWE hadn't heard of before. I have a tip and in the rear of the stock left IC there is a tranny oil cooler bolted to it. the instructions didn't mention it. I called and they said S4's don't have those. Mine does! Anyway I used several tie wraps and a strip of rubber to mount it to the stock upper IC mount since it isn't used anymore. I drilled a couple holes in the lower IC mount to add more ties. I used heat resistant ones and doubled them up in case of a failure. It's not that hard of a job to do. Fitment rating: 9. Good luck.
    Currently: 2017 Q7 Prestige 3.0 with APR tune.
    Formerly: 2007 S4 Avant 6MT; 2002 S4
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    had to cut a little on mine but such an easy install compared to rs4 which require a lot more cutting and struggling.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    very small cuts went very smooth for me the bumper fits fine although it seams like ever since i took it off the first time it doesnt seam to fit exactly like it should oh well. 9/10
    '00 Nogaro Blue S4
    Dec 27 2006
    01 s4, 14 Q5 TDI
    Pasadena,Tx
    check ur clamps periodically. had right lower hose come off today, while shopping with the wife. luckily had a screwdriver n the car 2min fix.
    fyi......didnt know i can search n post through my ps3:)
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    does anyone know if this kit can handle 500+ whp? or what it's limits are? i'm really curious..
    edit: i know this thread is old, but i figured i'd bump this up instead of making a new thread
    2001 Audi Allroad 2.7T, 2000 Audi A6 4.2
    2003 Audi A4 1.8T (sold), 2002 A4 1.8T (sold), 2001 A4 1.8T (sold), 2001 A4 2.8 (sold)
    Jan 09 2009
    FL
    9/10 fitment
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    My drivers side sticks out. Can't get the bumper to fit correctly. I have to replace the bumper anyways so I'm not worried about it until I get the new one.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    i had installed these on my friends car, we had to trim the shroud not the bumper down by the fog lights
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by BlazinB5 View Post
    On K04s without alcohol injection your IATs will rise 15-20*F running 24/25 psi on BW K04s. On other turbos I have seen temps go up as much as 30*F, meaning the turbos are probably running out of their efficiency range blowing hot air. I would say if you're running a setup making 500WHP/600+ flywheel horsepower, I'd look into larger SMICs like ER's, or go with a good FMIC.
    If you run alcohol injection on the setup, you'll be more than okay as the AWE's have a great ability to recover quickly. I have big meth nozzles on my car and I have flat lined IATs, if not dropping sometimes. I'm about to get rid of the AWE's and go to ER's, for sake of wanting even better cooling.
