    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    overheating issue
    Ok well this relates to another thread I started but I figure start another otherwise I get confused so I threw obd code PO117 but my check engine light didn't come on I just checked it just in case and who knew there was a code.
    PO117 = Engine Coolant Temp Sensor Circuit Low Input
    what does that mean and how do i fix it?
    Thanks.
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Re: overheating issue
    Change your ECTS it's bad.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    on the rear of the head there is a plastic coolant flange. the sensor is located right there, is either green of blue. easy access.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    May 18 2008
    SOOOOOO Cal
    ok thanks guys, I see I need the blue one but the I dots at autozone aren't much help so I just got it through ECS now I have to wait.
    Oh and you think I might as well get A new MAF and N75 valve I'm getting really low boost 5psi and I'm pretty sure I'm not in limp mode because I only have that one code.
    But then again NO body ever really lists all the symptoms of going into limp mode
    not to mention that people tell me my car doesnt have a limp mode ( Audi A4 B5 1999.5 1.8T Quattro Tip.) just in case I pulled the plug on the battery for like an hour but I havent tested how it runs ( heating problem) So until further notice I guess I'm not going any where, I think I'm going to get a B7 next year and keep my B5 for goofing around and shit.
    Again Thanks guys.
    Sep 14 2006
    Lansing, MI
    any time buddy, thats what we are here for.
    SOLD
