    Established Member Two Rings skiaudi's Avatar
    Nov 12 2007
    06 A4 2.0T quattro 6MT
    oil light question
    today i got the oil light that says min next to it. i assume this means low oil, and the dipstick confirms that my oil is low. i know this is a rookie question, but do i need to add oil or do i need to change my oil? is it bad if i drive another 30 or so miles with this light on?
    thanks
    Light Silver Metallic | Ebony
    Jan 06 2008
    Dacia Sandero
    Arizona
    Re: oil light question
    It means add.
    Check the oil level. It's not recommended, but you could get away with it. I recommend picking up a quart of oil though.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Nov 12 2007
    thanks for your help
    DUH! an Audi
    los angeles, CA
    get some oil, dont want to run for long period of times with low oil. It also depends how oil the levels are. Dont drive to aggressive till you add oil.
    Check for leaks...for a reason why oil is low
    I think our cars use mobil or castro 5w30 synthetic, but call your local dealer and ask what they use.
    -randy
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    funny you post this thread .. I just had the same thing happen to me. I always carry a quart of Oil just in case. so it worked out ... but now time to schedule a oil change!
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
