Results 1 to 13 of 13
    Senior Member Two Rings Grk_A4's Avatar
    Sep 18 2007
    Philadelphia
    I think I have a pcv problem.. Need some confirmation sorry for the long post
    Ok so here it goes. For the past couple weeks I start my car for let's say 30 seconds and then just pull off. As I pull off it seems as my car is bogging out (for lack of a better term). It almost feels like when you let the clutch out a little too early and your car starts to jerk forward. This happens when I am not in boost. Also when I am WOT in second gear my car spikes to about 18 psi then drops below 15 while I am closing in on red line. However in third gear I spike to 20 psi and hold 15 to red line. Lastly while I am WOT there is a loud whistling sound which sounds like someone squealing while fluttering their tongue. If that makes any sense.
    Anyway I thought it was the DV at first after hearing the loud fluttering sound but when I installed my boost gauge and saw that I was holding boost pretty well I have come to believe that it is my PCV. Also I don't think my car would bog out and jerk forward as I first start it and start driving if it was just the DV. However I could be wrong.
    I apologize for the long post but any help is appreciated. I plan to get the car on the lift this weekend and check the DV while I install my test pipe. But if I can narrow down the problem to the pcv then I will switch that out when I install my TP.
    Thanks for the help fellas. Sorry for such a long post just wanted to make sure my description was sufficient in order to receive some feedback.
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Re: I think I have a pcv problem.. Need some confirmation sorry for the long post
    sounds like the DV.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Do you have a check engine light? If its not the pcv or dv then I would check for a boost leak along the hose that connects to your boost gauge. Start at the engine at the back where its connected and see if the hose is cracked or loose. Hope this helps and I hope its an easy fix.
    Veteran Member Three Rings Josh_877's Avatar
    Aug 24 2007
    Chicago Suburbs
    just to be sure, will our cars throw out a CEL if the PCV or diverter valve are having issues? meaning will a CEL come on ALWAYS or could it go unnoticed by the ECU?
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    I have the same squealing on my car at high rpms too, i think there was a thread while back about this.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Sep 18 2007
    Philadelphia
    Alright thanks for the information fellas. I'm going to check the DV when I get the car on the lift this weekend. I'm also going to check my line for my boost gauge to make sure I don't have a leak there. I'll keep you guys posted. Thanks.
    Feb 22 2008
    ma/ct
    quick check for the breather, loosen your oil fill cap and start the engine. if you cant pull the cap up then you verry likely need a breather. a bad breather should set a light and would make a squeeling noise much like a serp. belt.
    Junior Member Two Rings hotgo's Avatar
    Nov 15 2007
    Waterloo, Ontario
    My '08 is experiencing the same issue... for the first 30-60 secs or so, the car feels like it's running on a few less cylinders. Stuttering and bogging out... even when applying the gas very gently. Afterwards, it runs great.
    Any tips?
    2008 A4 Avant SE 2.0T MT6 Quartz Gray w/Bluetooth, Sport Suspension, Rear Sunshades, Convenience Package
    Registered Member Two Rings OceanBlueB7's Avatar
    Oct 15 2007
    Ocean Blue Pearl '06 A4 2.0TQT
    Boise, Idaho
    Mine's at the dealer right now for similar symptoms. They diagnosed it as the intake-flapper motor failure and the PCV valve. Might want to look at those.
    Established Member Two Rings hhuynh14's Avatar
    Jul 01 2008
    2008 A4
    Orange County
    anybody seen this yet? there a fix for the PCV valve for the GTI.. I assuming it will work for the A4... check it out
    http://www.bshspeedshop.com/store/pr...at=1011&page=1
    http://www.golfmkv.com/forums/showthread.php?t=58465
    Sep 18 2007
    Philadelphia
    That would be great if it matched up with our a4's
    Oct 15 2007
    Boise, Idaho
    I'll second that. Looks like a better design for a boosted engine.
    Registered Member Two Rings navi604's Avatar
    Mar 20 2008
    Vancouver
    so ... does anyone know if this fit B7 A4???
