boost leak will not cause limp mode ALL the time, but i believe that if it is pretty big then it would throw you into limp. many many things can cause limp mode. its your car telling you that there is a problem. you can either take it somewhere to get it checked out and fixed or you can take it to your nearest kragen (or any other establishment that will vag your car) and have them vag it and search for the problem here on the forums.
to reset your car just take off the positive terminal on your battery for like 15-20 min and that will reset fyour ride most of the time. somtimes it won't help. also, make sure that you have the radio codes for your car or else you will be driving in silence.
