Results 1 to 4 of 4
    Registered Member Two Rings FourBlackRings's Avatar
    Jun 02 2008
    Monrovia, MD
    Boost Problems?????
    ok heres the short version. went to waterfest and got my 98 1.8t GIAC flashloaded some new shit they were doing and i am only boosting at 13 psi. shouldn't i be running like 20psi?
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Re: Boost Problems?????
    wow, nobody chimed in on this probably because they wanted you to use the "SEARCH" buttom. I will help you out with this though. My guess but just my guess...
    Car before stock...
    Car now new chip...
    car still has stock vac/boost lines and all stock rubber pipes...
    Car has more boost and can't habdle it...
    Just my guess. Do you have a boost gauge and what are you running at vacuum? I would do a boost leak check and see if you are leaking somwhere, you might not know and find somthing under boost, I have found some weird sh**.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Jun 02 2008
    Monrovia, MD
    i am running 22 at vacuum
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    Vac line boost leak? Stock DV no good?
    You're going to have to look at your lines and see whats wrong.
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
