Originally Posted by
fatal8446
when i start it i get 'LN 2' come up were the trip distance should be for about a min, whats that mean?
That is the Inspection 2 notification.
1) Reset the Service Reminder Interval (SRI) for instrument cluster to remind you SERVICE DUE!
On instrument cluster, hold right button, and turn ignition on (don't start car). Release button. Display should say SERVICE or SERVICE OIL.
Either push-in, or pull-out left button, and hold until display clears. Display should then read SERVICE 8000, or SERVICE ----.
Note: That 8000 is in miles, and it's a pretty damn long interval for the 1.8T. I use VAG_COM to reset the SRI, and set it to 5000miles.
Note that there is no point to setting the interval any lower than 8k. Next time I plug the vag-com in I'm going to set it as high as possible.
