Results 1 to 25 of 25
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Last cry for help... $50 REWARD to winnar!
    Instead of posting random logs an what not, can someone show me a link or tell me what I should be seeing as far as...
    1) MAF readings
    2) AFR readings
    3) Timing
    4) IAT
    5) Anything else that is important
    I have been trying to figure out for almost 2 years, the problem with my car... I am getting a low boost request as well as low AFR request... Car is requesting 9.8AFR from 4500 rpm on up, also at 4500 my requested boost is around the 10-14 range... Can I also get some mechanical things to check? Things replaced so far are MAF, injectors, o2 sensor, IAT sensor, CTS, coilpacks/plugs, vacuum lines, check valves, PCV system, DV, FPR and NONE of the listed helped/fixed the problem... Someone mentioned I replace/remove the combi valve and SAI pump, but I don't see how those can cause my condition when the car is warmed up... Yes, it sounds like a quiet vacuum on cold mornings... When I disconnected the FPR, my requested boost went up to where it should have been...
    What are the syptoms of a soft limp? What can cause soft limp? Running rich could cause it? Rich running from a FPR? I live in BFE and have no one within 60 miles that I can swap parts with... I have even offered buying beer for them or even a KEG! I haven't gotten help yet... Seriously, the person that helps me find this, I will paypal them $50...
    Car is a 2001 1.8t with GIAC X, 5 speed, Borla V2... If I cannot fix it soon, I am selling the car... CHEAP...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Last cry for help... $50 REWARD to winnar!
    This must be bugging the ish out of you ehh? I'd just recommend swapping ECUs man. Do you have a stock one? I have a stock one waiting for a future but I'm scared to loose/have it broken if I ship it to someone. The reason I say this is then with a different or even a stock ECU, you can check if the requested boost is normal and now low like yours. Give me block numbers you want me to log on mine and I can send you the data of my setup which seams to be running fine.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Mar 04 2007
    nothing
    nowhere
    Yeah, it's buggin me! Car is slow as shit! LOL! But not as slow as my moms MkIV 2.0! LOL! Slowest turd I have ever been in!
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    since it is a B5, i highly recommend to call VAST performance. B5 oil runs in their veins.
    I hear Mike - aka piggy is the shiz.
    http://vastperformance.com/
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Jan 21 2006
    6MT BT Avant Ti
    RI
    My brother got a Mk4 2.0 and its not that bad. You'd probably be happier with it as it wouldn't cause you headahes all day.
    Mar 04 2007
    nothing
    nowhere
    Yes, there is a tempting 2002 Subaru WRX Wagon in town here for sale that is looking tasty... And Dr... I will see what they say... Thanks...
    ΜΟΛΩΝ ΛΑΒΕ
    Jan 25 2006
    A4 2.0T
    MD
    You disconnected the FPR (Fuel Pressure Regulator) ? I sure hope not---- could have gone boom with that one (assuming you hit boost with it disconnected).
    Mar 04 2007
    nothing
    nowhere
    Yes, I hit full boost with it disconnected... The leanest my car got was a dead even 13.0 which, yes it is lean... I still didn't get any CF's either on block 20...
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    pull out some fuel with lemmiwinks, its worth a shot
    Mar 04 2007
    nothing
    nowhere
    Tried, didn't do a thing... Plus, lemi is across the whole band... I only have the problem from 4500 up...
    ΜΟΛΩΝ ΛΑΒΕ
    Jan 25 2006
    A4 2.0T
    MD
    What is your afr @ idle?
    Assuming the tune is good, it sounds like you have a leak after the MAF. How does the car run with the MAF disconnected?
    Mar 04 2007
    nothing
    nowhere
    Runs same with MAF disconnected. MAF isn't the problem... At idle it is 14.7... My 032 trims read 0.2% and -2.3%... Disconnect the FPR and the trims jump to 3.8% and driving is 4.3%... May have been -4.3% but cannot remember... Brother has my car right now... There is no leak anywhere as per a 30psi test... (Didn't realize it was 30 psi due to a cheap regulator on my good compressor!)
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    I agree. Swap Ecu's or possibly knock sensor? 13:1 A/F should have had knock readings.
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Mar 04 2007
    nothing
    nowhere
    Unless I wasn't running enough timing... Does anyone have a good timing log I can look at?
    ΜΟΛΩΝ ΛΑΒΕ
    Mar 04 2007
    nothing
    nowhere
    No timing?
    ΜΟΛΩΝ ΛΑΒΕ
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Did you ever have someone check to see if your fuel pressure is correct or swap out your fpr for a new one?
    Mar 04 2007
    nothing
    nowhere
    Swapped FPR with an old one laying around here... No go... I would still like to check pressure however... I just don't know where to get the t at... Or gauge... Would a cheap one from Autozone work if they have them in stock?
    ΜΟΛΩΝ ΛΑΒΕ
    Jan 25 2006
    A4 2.0T
    MD
    Buy a FP guage from ECS tuning.
    Mar 04 2007
    nothing
    nowhere
    I don't have a job... Trying to look for "cheaper" and "reliable" alternatives... Yes they exist...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Won't really be able to check fuel pressure while driving... Unless you have an in-house dyno. I would check your mom's, dad's, sister's, brother's, best friend's, and/or girlfriend's car to see if they have a Bosch-style FPR you can borrow and swap it in; assuming their car runs just fine though.
    "You know you have a bad idea when Ford guys are making fun of you."
    Jul 07 2004
    socal
    Quote Originally Posted by chris164935 View Post
    Sure you can, just need a gauge setup that uses a sender. I used to run one, still have the gauge in the car but pulled the sender out. I actually had 3 different ways to read my fuel pressure at that time.
    Apr 18 2007
    Orange Park, FL
    How "cheap" was this setup?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Maybe the Mk4 2.0 has the same pressure FPR.
    Jul 07 2004
    socal
    SW fuel gauge $88 from 42DD. They also sell the inline T for $15.
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by nebone22 View Post
    I'll double check but I think it is a 3 bar...
    ΜΟΛΩΝ ΛΑΒΕ
