Results 1 to 7 of 7
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    Anyone have any experience with stock manifold T25 adapter?
    I would assume this would make your turbo about an inch lower then using aftermarket t25 manifold, correct? I have the adapter plate mated to the gt28r t25 turbo and am worried about fitment with new manifold or if I want to change my downpipe setup in the future.
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Jun 01 2008
    Apopka, FL
    Re: Anyone have any experience with stock manifold T25 adapter?
    spend the $125 and buy a atp knock off, anything less is cutting corners and that's something you don't want to do with a bt. if you use the stock manifold you are talking about 300+rpm increased spool times just to save a few bucks. if your dp has a flex pipe the old dp will probaly bend to fit but I'm sure it won't be pretty and make contact with the body somewhere which is a bad thing
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    stay away from adapters. far away
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Dec 14 2006
    Halifax, NS, Canada
    SPA T25 is like $325 shipped.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jan 22 2007
    NNJ
    i currently have the adapter plate. Full spool is pretty late (over 4k) I have heard this is because of the stock mani and I have heard others (mike hood) say stock mani would cause sooner spool. Im def planning on getting a mani just not sure if im gonna need to redo the exhaust setup.
    2012 Cayman S Track
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Would cause sooner spool because its like blowing throw a straw that you have just squeezed.
    Get a proper manifold.
    Sep 17 2006
    SLC, UT
    ^although i have no first hand experience. from everything i've seen(AWE's GT28r setup mainly), it causes later spool. at least, there's got to be a reason that my 28rs spools to 20psi at 3800rpm(at 4300ft elevation). and AWE's GT28r setup doesn't spool 20psi till after 4k rpm's at sea level
    also, i would imagine top end flow would be horrible
    Current:
    Previous:
