Thread: P1138
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    P1138
    Caused by what?
    error code p1138
    i had to take my 02 defoulers out of my passenger side downpipe. cause they were stripped... could this be the reason?
    vac leak? etc?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Dec 06 2007
    Calgary, AB, Canada
    Re: P1138
    Looks like you're running a little lean. Yeah, boost leak could be a cause.
    Feb 28 2007
    chicagoland
    Re: P1138
    i have another..says idle to high over expected
    sounds like a vac leak.
    now i gotta find that issue.. as well as my charging issue..
    and i thought i ALMOST golden.. damn audi's
    Nogaro 01 s4
    620whp 93octane
    Dec 06 2007
    Calgary, AB, Canada
    Re: P1138
    Yep, air leak is probably the name of the gremlin that lives under your hood.
    LOL! You're NEVER golden if you own an S4...
    Feb 28 2007
    chicagoland
    Re: P1138
    yea this is true.. at least the car runs and drives somewhat ok.. i drove it 100 miles and then to work today.. gawd.
    Nogaro 01 s4
    620whp 93octane
