    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    oil grade for summer
    I'm doing an oil change during this weekend, I'm going to be changing to Royal Puple just to try it; I'm even going to dyno it to see if theres any hp/tq gains. The thing is, I live in Puerto Rico, and here the temperature is always around 85 degrees, and on summer its around 90 during the day. If I cant find any 0W40 Royal Purple, what other grade could I use? 5W40?
    Thanks,
    John
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: oil grade for summer
    You should be concerned with the higher number. (40) That is the viscosity of this multi-grade oil at 100°C (212°F) operating temperature.
    The 0W or 5W refers to what has historically been designated as "Winter". How well will the oil circulate in cold temperatures. A 0W oil is tested at -35°C, a 5W at -30°C and a 10W is tested at -25°C.
    Multi grade oils like 5W40 designate how they flow (viscosity) in cold (5) versus warm (40). A specific oil will have high viscosity when cold and a low viscosity at the engine's operating temperature.
    5W40 should be fine for you down in PR. I'm running 5W30 year-round and I'm up in the NorthEast.
    -Doug
    Jan 18 2005
    Puerto Rico
    cool! thanks a lot!!!
    FlexTuning
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    0w30- mobil one..
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by A4_ever View Post
    0w30- mobil one..
    Same here.
    CEO and General Manager of the AZ Pedal Responce Team
