Results 1 to 6 of 6
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Trouble with Detail Spray
    I got the detailing bug recently and picked up some basic Adams products. I'm not real happy with the Detail Spray though, it leaves smears that don't rub off easily / at all (black paint). I think it's water based, and a sample bottle I have of some other "Insta-wax" (or whatever) works a treat.
    I hope I'm doing something wrong like too much; too little; too fast; too slow etc, any opinions or experience with this product here? I have a gallon of the stuff!
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Re: Trouble with Detail Spray
    I am not sure about Adams products but on some if the wax is thin removal of the spray can be difficult.
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    Nov 13 2007
    '07 A3 2.0T
    Tampa, FL
    how are you using the spray? Are you spraying then wiping with a mf or are you letting it dry then attempting to buff?
    I use the Adams all the time on my blue car and have not experienced this problem.
    May 18 2008
    Spraying and wiping straight off with mf cloth, sound ok? Easiest to see with low sunlight.
    Dark blue car? Check it out when the light is at a very oblique angle.
    Veteran Member Two Rings Dwaller's Avatar
    Nov 17 2004
    Dahlbach stg3+ tip A4
    L.I. NY
    Quote Originally Posted by GotRS? View Post
    You have to be doing something wrong I'm addicted to that stuff I use it on everything on my car! I cant say enough about it.
    Dahlbach racing stg3+ DBR intake mani,DBR ko4-19,DBR tip chip,RS4 motor mounts,ER sport front mount,Stasis SS coilover's,H&R sway's,DBR cat back exhaust,Miltek HFC,custom AFE air intake, iForged rev's 18x8.5,Stoptech BBK front ST rotor's rear,Cam's and a bunch of other sh_t!!!
    May 18 2008
    Follow up:
    So I don't scare people off Adam's... whatever I was doing wrong has gone, probably not wiping off thoroughly enough because I'm not used to water based products. Maybe smears dried where I missed it and left the haze.
    Life is good
