Results 1 to 32 of 32
    Jan 01 2008
    Long Island NY
    This is my goal with my car.
    I was thinking last night and im not going to go BT Kit any time soon. My new goal is to have this done by September of next year. I want to get a high hp torque converter, 3000rpm stall speed converter (Launch Control), Statis 4:1 Differential, some weight reduction and S3 Injectors. I think with those mods on a cold day with race gas and can get this sucker in the 12's with a stock turbo. Call me crazy but i will do it.
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Re: This is my goal with my car.
    cool stuff
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    Good luck...
    let us know when your K03 blows up.
    that is if your motor mounts and clutch dont go first.
    Jan 01 2008
    Long Island NY
    No problem i'll give you a call.
    Established Member Two Rings MrRevesz's Avatar
    Oct 08 2007
    2012 Audi Q7 TDI
    Mid-Coast Maine
    Quote Originally Posted by Auditude2.0T View Post
    That's what i'm talking about!! Build that sucka up
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    I'll be the one to call you crazy then.
    Your Crazy!
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Good luck to you Pete. Sounds like a cool idea, however i think 12's are a little too ambitious but i will eat my words when i see it. Also why did you order the labree downpipe? didnt your exhaust come with a new one? the stasis differential is super expensive, let me know if its worth it.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Jan 01 2008
    Long Island NY
    I ordered the Labree b/c i have a stock downpipe. None of the exhausts for the tip come with downpipes.
    Apr 14 2008
    Oceanside, New York
    will the labree work with the tip? thats going to be a pain to switch - the metal by now i am sure has a nice tight seal as it heats up pretty good. Let me know when you get everything. Still interested in the stasis rear diff.
    BMW M3 ZCP
    Jan 01 2008
    Long Island NY
    john where did you get the Eurojet PCV Fix. i have a code coming up for pcv mechanical malfunciton and i think thats the problem.
    Jan 01 2008
    Long Island NY
    im probably a year out from the stasis diff. b/c im trying to save more for college.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Get the DIY shim pack the b5/b6 guys are using and make it 4:1 yourself, much cheaper. Weight is the key here, check out jet jockeys b6 if you need some ideas on where to shed the pounds.
    -Kris
    Apr 14 2008
    Oceanside, New York
    Eurojet - its really for the mkv gti but works on our engines. get it and ill show you how to install.
    BMW M3 ZCP
    Senior Member Two Rings Quigaboo's Avatar
    Jan 10 2008
    2008 A4 2.0t Quattro
    Bellmore, NY
    You must still be livin at home with your mom & pops cuz that's going to cost a few bucks!
    Cheers!
    Jan 01 2008
    Long Island NY
    yea im only 17, but i work, pay for my car and mods and gas, insurance. I just live for free.
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    good luck. IMO the BT kits coming up aren't putting out enough HP =(
    Jun 02 2008
    Are you sure you can get in the 12 second range? I'm not saying you can't, but that seems bold on the stock turbo. Let us know how it turns out.
    Jan 01 2008
    Long Island NY
    Yea im very confident in myself. Right now im in the mid 13's so i think with a better differential, lighter and some transmission mods high 12's is very attainable.
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Maybe get a set of some lightweight wheels for the track.
    Jun 02 2008
    Hopefully you'll end up with the fastest Tip.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    I'm confused, does the 4:1 change the torque split of the front and rear wheels? If so, how could that possibly make you go faster?
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    Quote Originally Posted by ImitationOfLife View Post
    He just might, it will be one of us!
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Registered Member Two Rings Teddy M's Avatar
    Jun 25 2008
    2008 Audi B7 a4
    Miami, Florida
    Quote Originally Posted by Quigaboo View Post
    Cheers!
    X2!!!
    i can use some cashh
    Black A4 b7 S-line
    -15% tints
    -Test pipe//downpipes
    -debaged
    -blacked out tail lights
    -exhaust with quad tips
    -S4 valence
    - hula dancer on the dashboard
    Jul 14 2008
    Stockholm - Sweden
    Living home is the shit! :D Specilly when the gas is around $10-11 a gallon in sweden. :)
    Current:
    - Audi TT Roadster MK3 2.0TFSI Quattro S-line (2015)
    Sold:
    - Audi A5 Convertible 2.0TFSI Quattro S-line (2012)
    - Audi A5 Coupé 3.0TDI Quattro S-line (2008)
    - Audi A4 Avant 2.0TDI B8 Quattro S-line (2008)
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Quote Originally Posted by Zebman View Post
    More power to the rear wheels makes your car faster. Think about it, why are the FWD's faster than Quattro's? They say the no. 2 mod that makes the Stasis packaged A4 faster, next to the chip, is the rear biased Stasis differential on it. They said it shaves .5 sec. 0 to 60.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Established Member Two Rings BlackB7Quattro's Avatar
    Apr 05 2006
    '06 A4 / '96 Cherokee
    Manchester, NH
    Hey man you need to get your priorities straight
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    mid 13s now? what was your exact time last time u dragged? 12s mean gutting your car to the point where its no longer a luxury automobile.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Dec 25 2007
    '06 A4, 08 R6s
    Quote Originally Posted by davis449 View Post
    FWD cars are faster due to the fact they are always lighter than their RWD/AWD counterparts, and lose less power to drivetrain friction.
    The differential still makes no sense to me. Maybe it keeps traction better under hard launches, or reduces drivetrain loss. I'm puzzled.
    2008 R6s
    Senior Member Two Rings NKI 337's Avatar
    Apr 24 2007
    Miami, Florida
    nice mod list.....
    ***** www.dubbersinc.com *****
    Veteran Member Four Rings dreamcar=rs4's Avatar
    Nov 04 2007
    A4 2.0T
    NorCal
    Yea I thought it was only for better power delivery out of corners. davis449 where did you hear this? If it takes .5 off of 0-60 I would order one ASAP lol
    Mar 05 2007
    San Antonio, Tx
    Quote Originally Posted by dreamcar=rs4 View Post
    It was in a Road and Track article last year on the Stasis Challenge Edition A4. Unfortunately the online version of the Article didn't contain the entire article they printed in the magazine. I will have to go home and see if I can find that edition. They explained that the No. 2 factor in making the car faster, aside from the chip tune, was the differential. The rear wheel torque bias is increased. That's why all the new Audi's are coming 40/60 front to rear power distribution, they behave more like a RWD and are faster off the jump. A good demonstration of this is the Top Gear comparo of the RS4, M3, & C 63 AMG. Watch the drag race portion. All of them "knew" the Audi would be slower off the line...they were all wrong. No it did get it's ass kicked by the end of the 1/4 mile but...whatever.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    I think that the high rpm stall is a great idea and will prob get you the most run for your money. You should look into getting a water/meth system so you can run on 100 octane tune with 93 gas. Also i would pm HID about his NOs system. All that could be putting you into the 12s if you time everything right and get a professional tune.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
