Results 1 to 20 of 20
    Senior Member Two Rings East2.7Six's Avatar
    Apr 18 2008
    Audi A6 2.7T
    New Jersey Shore/Philadelphia
    Engine Bay clean up
    whats the best products to use to clean it up.. i saw everyones engine bay at Waterfest and it was wayyy cleaner than mine! so what did you guys use.. to clean it up
    "Sometimes you gotta roll a hard six."
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: Engine Bay clean up
    i think a lot of people just use simple green
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Apr 18 2007
    ny
    Elbow grease, a wet rag, and a vacuum to suck up any leaves and dust.
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    yeh i have a bottle of "SIMPLE GREEN".. i just haven't used it..
    Apr 18 2008
    Audi A6 2.7T
    gotta try that out
    Feb 17 2004
    Sterling, VA
    1. Vacuum all visible dirt/dust while brushing with a soft bristled brush.
    2. Use a diluted multi-purpose cleaner and paper towels to spray/wipe the dirty areas.
    3. Dry thouroughly and dress it up.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    I just did mine before waterfest..
    1. Vacuum
    2. Spraied Adams APC diluted and used a soft brush to get the dirt loosen up
    3. Pressure washed the whole engine..
    4. Dried and then Dress up..
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by VJ's A6 View Post
    1. Vacuum
    Vimal you pressure washed the engine?!?!?!?
    Brett - Moderator
    Issue?: email me.
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    yeah don't do that, lol
    2004 Audi A6 2.7T
    Active Member Four Rings kingofnyc's Avatar
    Jul 02 2007
    Queens, NY
    i used simple green.
    cover the intake. spray it on the cool or cold engine and let it sit for a few min. then use an old toothbrush or some other brush to loosen up the dirt. then rinse it with water. do not spray water under preasure. let the water dry before starting the engine. after water dries use back to black for plastic. all done. sit back and enjoy your superclean enginebay.
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Quote Originally Posted by Daft View Post
    I pretty much do the same thing as you Brett but I also use a blower to get rid of leaves,water. dust or anything else that I can't reach.
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by blkrhyno View Post
    Yeah that's a good point. Forgot that step. I use my air compressor with the air blower gun, dirt goes a-flyin'!!
    Brett - Moderator
    Issue?: email me.
    Jan 23 2007
    Brett-- I used the pressure washer to rinse the engine off.. I didn't directly point to the engine.. I used it on an angle.. It worked really well. So far I don't have any issue..
    APR Stage 2
    Feb 17 2004
    Sterling, VA
    You're a lucky guy. I never spray water into my engine bay.
    In my teens, I worked at a car stereo/detail shop and some of the guys would use a hose to rinse engines off while they were running. 90% of all these attempts resulted in the car not starting again for several hours and someone having to open/dry all ignition connections.
    Brett - Moderator
    Issue?: email me.
    Apr 18 2008
    Audi A6 2.7T
    lol ill try the blower and brush technique.... what did you guys use to dress up the engine? i dont wanna use somethin thats gonna leave a nasty residue behind.. my engine bay is filthy!
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by East2.7Six View Post
    I use this stuff on mine: Malco Perfect 10.
    Brett - Moderator
    Issue?: email me.
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    here is a link excuse the yellowing hoses.
    http://www.audizine.com/forum/showth...=engine+detail
    Apr 18 2008
    Audi A6 2.7T
    wow that clean up looks great..how long did it take?
    Feb 24 2004
    about 45 minutes.
    Established Member Two Rings cjslapshot's Avatar
    Mar 23 2007
    Dirty Jersey
    just cover your intake and maf with a plastic bag and power wash the whole motor. No harm can be done. I took a dish scrubber wand thing and scrubbed everything then just power washed it away. Looks brand new.
    free agent.
    buy my car.
