Results 1 to 27 of 27
    Veteran Member Three Rings freeflow's Avatar
    Apr 17 2008
    2007 A4 2.0T
    Manhattan/Miami
    Driving with RS4 sway not completely attached...
    Is it a horrible idea?
    I did the install yesterday and as many of you know it is a TOTAL PAIN IN THE A$$ if you try to use the stock brackets... so i ordered the correct brackets (8E0-511-439) and am having them overnighted to me.
    In the meantime, how bad would it be to drive LIGHTLY around to the store and back etc. without cornering at a speed higher than 2mph?
    Is this an absolutely terrible idea?
    thank you.
    2007 A4 2.0T - Brilliant Black on Black - Premium - 5% tint - 7 spd multitronic - APR 93/Stock - RS4 Sway - FLY's LEDs - CC'd - LED License Plate - Interior xenonmatch - Hoen Fogs - Debadged - VAGed
    Wish list: Stassis Coils, Carbonio CAI, HFC, 19" R8s, Ecode CF Hood, CF Rear Wing, ECS Blackout RS4 grille, S4 blades,
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    Re: Driving with RS4 sway not completely attached...
    the brackets are the same it's the bushings that are different.
    and yes it's a bad idea.
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    I don't have tires on my new wheels yet, can I drive on them?
    juusttt kidding, yes, it sounds like a terrible idea. Ride a bike.
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Apr 18 2008
    Jacksonville, FL
    i had the same problem. ended up cross-threading one of the holes and having to take it to an audi mechanic to get it fixed and installed proper. in the mean-time, i just used smaller bolts (that don't thread into the stock locations) and a couple nuts & washers to hold the brackets on. and...drive it easy with that setup, of course. had to go a week like that before the appointment with the mechanic.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Apr 18 2008
    Jacksonville, FL
    Quote Originally Posted by 80CID View Post
    the brackets are different. the brackets for the RS4 sway are bigger to accept the larger bushings. go ask your parts guy.
    SOLD 10/2011
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    just take the whole bar off and then you can drive all you want
    Houston
    Why would the bushings be bigger? The inner diameter would be bigger but the outside dimensions should not change. But mines been hanging on the garage wall for months now....so I don't know from experience yet. Besides you want as little movement as possible.
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    The bushing would be bigger to compensate for "greater" forces exerted on the car. Engineers that desinged the cars would assume that the RS4 would be driven a bit harder than a standard A4 so in turn, it would have beefer components. And as to the OP's question, would you drive your car with the wheels not attached properly? Probably not, I think the same logic would apply to any suspension piece "not properly attached".
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    They are NOT the same brackets.
    http://www.audizine.com/forum/showthread.php?t=225821
    More closely:
    Quote Originally Posted by greene08
    NOTE: The new brackets are larger than the stock brackets and fit exceptionally well. Anyone who says the stock brackets are OK with the larger bar is WRONG.
    Also, there is a picture on the board of a both the stock A4 and the RS4 brackets and you can visually see the difference in the sizes.
    I know this personally because when i picked up the brackets from the dealership it specifically states that the RS4 brackets are meant for the 22mm sway (super sport) and there is another bracket for the 20mm sway (sport) which is probably off the S4, and then a third which is probably for our bracket on the stock A4. I should have got the part #'s for all three to put this claim to rest.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Registered User Four Rings PerfCafe's Avatar
    Nov 27 2007
    is where we work on cars!
    Monterey CA
    Quote Originally Posted by GEkido View Post
    The proper part number for the larger bracket is "8A0511439" And I wouldn't recommend driving w/the sway "half on" I would put either your stock sway on or the RS4 sway on ... which ever is going to mount properly in order to drive the car.
    DUH! an Audi
    los angeles, CA
    why not just put stock back on?? I agree with the gods at performance cafe =D
    Feb 16 2007
    You can re-use the same brackets. A short cut to getting the stock brackets over the new bushings: hand tighten the top bolts until the threads are just started, then take a vise-grip and pull the bottom of the bracket inward against the bar. Let sit about 45 seconds. The bushing will be sufficiently squeezed and not rebound immediately. Remove the vicegrip and screw in the bottom bolt. Tighten.
    Apr 17 2008
    2007 A4 2.0T
    Manhattan/Miami
    Quote Originally Posted by PerfCafe View Post
    It was the "gods" at performance café (JB) that told me that the brackets are the same for the A4 sway and the RS4 sway when i ordered it from them... clearly they were wrong, and the part numbers quoted above are wrong:
    OEM RS4 Rear Sway Bar Brackets # 8E0-511-439 (the top brackets in the pic)
    OEM A4 Rear Sway Bar Brackets # 8A0-511-439 (the bottom brackets in the pic)
    The gods must be crazy....
    -1 rep for perf café lol... jk
    DUH! an Audi
    los angeles, CA
    gods make mistake too =x
    Nov 12 2007
    Grand Junction, CO
    You can get the bar on with the stock parts. My shop did it yesterday. Just takes a little bit of TLC. Makes a huge difference in handling characteristics of the car. The steering is so much more responsive.
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by freeflow View Post
    That's the picture I was referring to in my post above!
    Also, the part # you posted is correct. It's the same number I posted up in the FAQ thread.
    http://www.audizine.com/forum/showpo...&postcount=126
    -Anil
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    why what was wrong with the stock brackets? do they not fit the rs4 sways?
    H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
    Nov 12 2007
    Grand Junction, CO
    they do. i guess it just take a little more work.
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    spray some lube on those bushings and use every ounce of strength you have to hold that bracket on tight while you thread the screws.
    dont be afraid to use a lot of muscle. and beer. :)
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Jan 22 2007
    Fontana, CA
    What I don't get with this whole discussion about the RS4 Rear Sway Brackets is that the brackets/clips are a cheap part and obviously, as reported by other members and myself as being an easy way to get the sway bar on properly.
    They are only $8-$13 a piece. Not an expensive part really. Why not just buy the clips and do it right? I don't get it, spend 40K on a nice car, and skimp out on an relatively cheap bracket/clip.
    Why is this even up for discussion?
    -Anil
    Houston
    I stand corrected....but if it would of been me designing the RS4 sway bar I would used the same brackets (lower cost, this can add up on 10’s of thousands of cars) and used a “stiffer” rubber bushing…..but it wasn’t up to me.
    Btw why do they sell it as an up grade for the A4 without the brackets? Just add $20 bucks to the price….simple.
    Jan 22 2007
    Fontana, CA
    The extra 4mm of space between the stock sway and the rs4 sways need to be accounted for somewhere.
    the extra 4mm of space required the bushing to have a larger opening, that's a given. I don't know if this is true or not, but I would imagine the bushing on the RS4 is also stiffer than the stock a4.
    Fine they probably could have used a stiffer bushing on the base a4, but the fact that the opening on the RS4 bushing won't match the base a4 sway is enough for them to require different bushings and clips/brackets to make a tight/snug fit to eliminate play in the bar's movement. Not everything can be a one size fits all even if they want to save money.
    -Anil
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    I plan to use the stock bracket, simply because it works and I'm impatient.
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    I'm the one who did that writeup you see from the pictures above. BUY THE LARGER BRACKETS. They have the correct fitment. Car parts were not meant to be wrenched on.
    Lover of all things motorsport, powersport, sport.
    Apr 25 2008
    Miami, FL
    Quote Originally Posted by Sly Raskal View Post
    In my particular case it wasnt about saving money, it was just not included in my group buy. I went ahead and used some good ol' elbow grease and managed to get it on. Not saying that having the larger brackets wouldnt have been easier, they just werent around. And really, having an easily mounted mod just sitting there waiting for some brackets just doesnt sit well with me. I'm like a kid in a candy store.
    Apr 17 2008
    2007 A4 2.0T
    Manhattan/Miami
    Thumbs up Re: Driving with RS4 sway not completely attached...
    To answer my original question.... I called my local audi dealer who told me it was no problem at all to drive without the sway bar or with it not fully attached.
    The new larger brackets came in 2 days later... and fit like a charm. 5 mins a side to install with the new brackets... no cursing... no NEEEEEd for beer (still had a couple tho of course)... no straining.
    For anyone trying to do this mod in the future.... get the right size brackets. It is a royal pain in the ass to try to reuse the stock brackets which are NOT the right size.
    test drove around a bit earlier.... LOVE THE DIFFERENCE. Best bang for your buck since i got my APR93
    Senior Member Two Rings has6's Avatar
    Aug 06 2007
    '21 SQ5 | '20 XC40
    Brooklyn, NY
    I had the same problem with the stock brackets on my B6 A4 and I drove around for a day or two without one of the brackets on one side of the RS4 sway bar and my car handled like a Grand Cherokee. I'm pretty sure unless you're loading the car constantly through the corners, it's not going to kill you to drive with it loose/missing/disconnected/etc.
