Results 1 to 25 of 25
    Senior Member Three Rings Bryson's Avatar
    Apr 07 2008
    2006 B7 A4 2.0t (not s-line)
    la quinta, California
    HOW-TO make your hid cut-off beam SHARP and COLORFUL! DIY
    ok guys, and girls, heres what ive been working on, it all started when i kept seeing my headlight beam on walls and stuff and hating how blurry the cut-off line was, so i took action!
    heres waht it looked like before:
    and a close-up of how blurry it is!
    and no color, just yellowish-white..
    now after some intense mods to the projector unit, i acieved this!
    the beam pattern seen here is only achievable through making a custom shield, mine, from a pepsi can, the stock beam does not look like this just by clearing the lense, also the shield is curved, not flat, which carries the sharp-ness along the entire beam (see DIY later in thread)
    heres a close-up, see the intense blue-purple band? yumm!
    intense pink-purple color emitted at edge of beam, keep in mind im still running 4300k bulbs, you can see the yellowish color on the ground..
    pics are from cell phone so theyre actually a little sharper than this, when i update you will see,
    heres pics of the headlight completed and mounted, it was starting to get light out so its a lil harder to see..
    and the brights..
    so to sum this one up i did it because im a fan of sharp colorful hid's
    the stock ones preform just fine i just wanted to be custom, and i had the knowlege, so i put it to use
    i will be updating later this week with the other side done and REAL HD PHOTOS, so stay posted.
    If you too are interested in doing this, i wrote up a little DIY on how i did it. It may be a little confusing so i will be happy to answer any questions..
    PEACE!
    <DIY>
    first step, sorry i dont have pics for this first part so i sorta made one. Once the headlight projector is out of the headlight, remove the lense from the projector. Now go down to the store and buy clear spray-paint, (i bought krylon brand).
    Now mask off the flat part or bottom of the lense(FIGURE 1.), you dont wanna get paint on this part, now get real close (like one inch) to the lense with the spray can, and spray hard in one spot for ten seconds. The paint goes on so thick its like water, all the excess runs down the lense leaving a thin perfect coat of clear paint on the lense, put a small cup over the lense so it can dry without lint or dust falling on it, dry takes about an hour. The purpose of painting the lense is you are filling in the small dimples in the lense, these "dimples are only visible if you get real close to your lense and look through it in the light(SEE FIGURE 2.) , the purpose of the dimples is to slightly "blurr" the image of the cut-off shield so that the beam is'nt perfectly sharp, this allows for a smooth transition between dark and light as the car bounces, however the frostyness of the lense makes for an ugly and blurry cut-off.
    now that the lense is dry, re-mount it into the lense holder of the projector, but rotate it to where the line going through the lense is vertical, rather than horizontal (FIGURE 3.), the line in the lense blurrs the cut-off aswell, so by rotating it you are getting it out of the path of the beam. The actual purpose of the line that goes through the lense is to throw up excess light so you can see a little bit above the cut-off, however, this makes your lights appear brighter than most, i've been flashed by oncoming drivers.
    NOW for the next part, THE SHIELD! and if you dont know what a shield is, its the meatal plate in the projector that moves. Now if you dont care that the beam flares up on the left and right you can skip this step(FIGURE 4.), i however, wantted a straight beam with a bigger and more slanted step. Here you can be creative and make any style steps you want, i chose a slanted one because i loike the look and its big so i can illuminate more stuff on the right like signs, pedestrians ect., without blinding oncomming drivers.
    if you look in FIGURE 4., you can see my illustration of the factory shield, look familiar? if you look into the headlight of your car with a flashlight you can actually see it. Anyways you can see how its designed to where it flares down on the sides, but after focusing through the lense at a distance this "image" is flipped up-side-down to reveal your headlight beam (FIGURE 5.)
    Now you can see how it flares up, not good if you want a straight beam...
    so now to the custom stuff! drink coke? no? well howabout Pepsi? hah well to make the shields i used a pepsi can.
    One. because it is already round shaped,
    and Two. because its thin and easy to cut.
    heres some pictures of the cut shields..
    okay now you may be wondering how to cut the shields, look at FIGURE 6.
    cut out a rectangle about 3/4 in. tall by about 3in.
    you must make sure you cut straight across the can to avoid a lop-sided curve.
    now that you have your rectangles, cut them to be the exact same size and tape them together(one on top of another) the reason for this is so that you can cut both shields at the same time, this way both sields will be identical.
    using a ruler or straight edge, trace a line across the top of the rectangle(red line on FIGURE 7.) make sure the line is no more than half a centimeter from the top, or your step will be HUGE!
    now you have your line drawn on the rectangle, start cutting along the line with a new pair of scissors(for best cut) and stop half-way through the line.
    now from the top, cut your desired slant and stop just as you intersect the first cut
    NOW YOU HAVE A CUSTOM SHIELD!
    MOUNTING THE PEPSI SHIELD TO EXISTING SHIELD..
    okay now it gets a little tricky, theres an external silver plate on the shield that has an (RV) written on it, cut this off completely.
    This will leave a small "key-shaped" hole in the shield, take a screw with a matching bolt and get your custom shield, poke a small hole in the custom shield so that the screw can go through both shields(see below photo)
    now you can see how i mounted the new shield to the old one, also make sure the new one sits just barely over the old one, make it sit too high and your beam will have a smiling effect (see below pic)
    heres another pic from an above view
    the reason i mounted the shield this way is so that i can adjust the leveling of the beam, if its too tilted to the left or right, i can re-adjust the shield.
    you will also need to make sure the new (curved) shield does not hit when your brights are on, i just pulled the shield forward while the projector was assembled so i could see what to trim off. To make the shield not come as forward as before you will have to bend some of the tabs(RED CIRCLE) on it so that they rest on the lense-holder(BLUE CIRCLE) when in the open-position
    heres a pic of the open position, see how the shield is trimmed to fit, and the bent tab is resting on the stem of the lense-holder..
    Now the final step is to test your projector for sharpness and balance, what i did was parked my car on my street, opened the hood, plugged in the headlight shell to the car and plugged in just the wire that goes to the bulb, this way i can move around while testing, you will most deffinately have to bend the shield while the projector is on so you can achieve the sharpest beam possible, but since youre shield is already round, the tweaking will be minor.
    after you get the beam sharp, you now have to make sure its level, so that means mounting the projector back in the leveling motor assembly and mounting it all back into the headlight, dont put the actual headlight lense or any of the chrome pieces on, just the part that holds the projector, now mount the headlight on the car and turn on the lights, make sure that the line is level, i used my garage floor as it is level...
    i know this is alot of crap but you really cant cut corners on this headlight stuff, its better to do it right!
    now that its all level, clean up everything (wipe lense only with microfiber towel or you will scratch) and re-assemble, i like to wipe out all lint particles right before pushing the lense on, who wants to see dust all in your headlight? GHETTO!
    to ensure a sealed fit of the lense i bought clear window sealant from the store, comes in a squeeze tube. i put the sealant in the groove around the edge of the headlamp, shot it for a min with the heatgun, then pushed it on.
    DONT FORGET TO PUT BLACK LENSE CLIPS BACK ON!
    now put everything back to how it was and have fun watching your razor-sharp beam bounce around, all while dazzling people around you with exotic colors
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    Re: HOW-TO make your hid cut-off beam SHARP and COLORFUL! DIY
    dope work man, I think I might do the clear spray paint mod to my ecodes I have sticking around.
    Good work dude, kinda ocd but ya know that already I think
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    if i already have ecodes and i dont need to mess with the cutoff i can just do the lens right?
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    I don't know if I would put a coke can in my headlight housing but I like the creativity and "MacGyver" style work you did.
    I have to admit I love the sharp beams. How much would just the spray paint portion and rotation of the lens improved the bean clarity?
    Lover of all things motorsport, powersport, sport.
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Amazing. Wish I had the skills to pull this off.
    Apr 07 2008
    yes you can just spray the lense to sharpen the existing beam
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Bryson, you do some serious headlight modding dont you, it seems like one of your weekend hobbies lol
    I am so glad I have ecodes with a very sharp cutoff, nice modification though.
    Established Member Two Rings GEkido's Avatar
    Apr 25 2008
    Miami, FL
    Bryson, you got a lot of time on your hand's man. Good Job on the lights though! Definitely MacGyver style!
    2021 S5 Sportback | Glacier White | Sport Package | Black Optic | APR 93 Tune | APR FMIC | AWE CF Intake | 034 F.S.B. | 10/12.5mm Spacers
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    If my car is a 06 A4 2.0T from the US with stock adaptive bi-xenons, are they E-code or not? This is so damn confusing. Does E-code refer to the cut-off shape or the material texture and design of the projectors?
    Dec 27 2005
    New Orleans
    i thought our cutoffs were decent already..til i saw this..good work
    Apr 07 2008
    Quote Originally Posted by airborneriflema View Post
    well im pretty sure your headlights are the same as mine if you have an 06
    Apr 07 2008
    Quote Originally Posted by a4b7 View Post
    thanks, im going to eventually just buy clear 3 in. lenses and ill show you guys how to do that
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    gonna call you ModGyver. Don't even understand what the hell you did but it looks good.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Cool, you got a Pepsi can inside your headlamps.
    Registered Member Two Rings navi604's Avatar
    Mar 20 2008
    Vancouver
    Thanks Bryson for the great DIY ... I"m gonna try that later when I do the CC mod.
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    wow thats some crazy DIY... i dont think i would ever be able to do that.
    H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    great work. amazing diy. are you sure you dont work for pepsi? how about doing a diy on s6 led fog lights? ill give ya a buck. :)
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    So, do you have to do the oven trick to get access to the projector. Also, where can we buy a clear 3in lens that you mentioned?
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Two Rings tgt's Avatar
    Feb 18 2004
    Wisconsin
    Bryson -
    Thanks for the terrific write up! I've always preferred the colorful projector of my past Acura TL, and this will certainly get me closer.
    To confirm, to sharpen the beam (and make it more colorful) using the clear paint (by the way, by 'clear paint' are you simply referring to clear coat/top coat?) to fill the roughness AND swapping the lens to a vertical position should accomplish this, correct? The only added benefit to creating the new shield is to create the 'stepped' effect?
    I will be doing the Clear Corner mod (so will have everything apart) on my '07 in short order, so this is the perfect time to do this as well.
    Travis
    Sep 10 2011
    None
    Write-up is useless without pics!!!!!
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    you necro bumped a thread from 2008.
    More relevant info is found at hidplanet.com
    http://www.hidplanet.com/forums/show...enon-projector
    In short, to get a perfect cutoff and even flicker throughout you need to fabricate custom shields. You can tweak the e46 projectors quite a bit with ZKW-r clear lens swap, RV shield removal and adjusting the set screw and get good results but due to the shield shape, peripheral blurring is inevitable.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    Quote Originally Posted by CrazyCal View Post
    Holy bump! From 2008. That's 5 years ago..
    Sent from my Throne using Crapatalk.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Four Rings kurupt_hawaiian's Avatar
    Oct 13 2007
    2017 Toyota Tacoma TRD Off-road
    Waianae, Originally Molokai
    Damn it...I'm having flashbacks!
    2018 Audi A6 Mythos Black
    (SOLD) 2007 Audi A4 Quartz Gray 2.0T 6MT
    Follow me on Instagram- @Kurupt_Hawaiian
    -Elias
    Apr 05 2010
    Actually Blurry cut offs make more sense....you don't appear to flash the oncoming traffic..its a gradual brightness....
    most of us are 'blinded' with this cut off expectation in the auto world.........
