Results 1 to 19 of 19
    Oct 11 2007
    Suburbia
    Stock Avus wheels with spacers......
    Hey guys, Whats the largest spacers I could get away with on the stock avus wheels, I searched and couldn't find the offset so thought I'd ask the crowd. I'm wanting to put 10-12MM spacers on the front and rear wheels, would that give me a rubbing issue? Keep in mind that I will most likely be dropping the car about 1" all around on some Vogtlands in the near future as well. Any info would be great, thanks!
    Established Member Two Rings ichibunz's Avatar
    Jun 03 2008
    Danbury,CT
    Re: Stock Avus wheels with spacers......
    I had 10mm spacers for my S4 no rubbing with a ride height around about 25". I even want to go 12mm-15mm for the rear.
    Oct 11 2007
    Suburbia
    Your talking about the stock Avus wheels right? What coilover/spring setup do you run? Thanks.
    Oct 11 2007
    Suburbia
    bump... anyone?????
    Registered Member Two Rings hackers4's Avatar
    Jun 12 2007
    Miami, Fl
    I had 10mm on the front and 15mm in the rear on a B6 with H&R coilovers and had no rubbing at all.
    2005 Audi S4
    MTM Fullback Exhaust
    ASR Engineering Test Pipes
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stasis Center Differential
    Stratmosphere SS
    BBS RS-GTs
    Oct 11 2007
    Suburbia
    your talking about the stockers right? not the BBS RS-GT's? Thanks.
    Jun 12 2007
    Miami, Fl
    Correct...on my stock 18" avus wheels.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    15mm H&R (rear only), lowered to 25.75'', no rubbing. Here's a couple past threads for you to peruse.
    http://www.audizine.com/forum/showthread.php?t=223586
    http://www.audizine.com/forum/showthread.php?t=214659
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Jun 03 2008
    Danbury,CT
    Quote Originally Posted by WinterRunner View Post
    Yes, stock with h&r coilovers.
    Jun 03 2008
    Danbury,CT
    Quote Originally Posted by S4J View Post
    do you use the same lugs for the front and rear?
    Registered Member Two Rings ososlow's Avatar
    Oct 22 2007
    LA
    is it ok to run different sizes spacers on the front and rear?
    excuse my stupid question but i think i read somewhere staggered setup is not good for the 4wd or something along that line. is different sizes considered similar to a staggered setup?
    Jun 12 2007
    Miami, Fl
    Staggered setup is referring to different size tires front and rear. Spacers don't affect tire size. You want to maintain the same size contact patch front and rear and same diameter front and rear.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Oct 22 2007
    LA
    Quote Originally Posted by hackers4 View Post
    i see! thanks!
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    no, anything bigger then a 3 mm spacer requires a different lug nut. Im not sure what the length of the stock lug nuts is, but if stock is 30 mm, then you should get 37-40 mm lugs for 10 mm spacers, and 42-45 mm lugs for 15 mm spacers. The theoretical 40 and 45 sizes (ones for a perfect fit) are optimal.
    Jun 12 2007
    Miami, Fl
    No problem...and ginkof is correct...you should be looking for bolts that are proportionally longer to the size of the spacer you use.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Jun 03 2008
    Danbury,CT
    Quote Originally Posted by ginkof View Post
    thanks.
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Different wheels on a B6 A4 but the same size and ET as yours ... I had 8 mm in front and 15's in the rear and sat at 25" fender to ground. No rubbing with 235/40/18 Toyo T1R's. When I went to same size GY F1's I had minor rubbing as they are known to run a bit wider ...
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Nice car!
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Quote Originally Posted by covertS4driver View Post
    Nice car!
    +1 but I'm a little biased
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
