Results 1 to 10 of 10
    Senior Member Two Rings rdguy's Avatar
    Oct 12 2006
    14%20Audi%20A4%20Quattro%20%26%2087%20M
    Mississauga
    ABS activating at slow speed??
    My abs brake system has been activating at slow speeds. It is an intermittent problem that does not happen everytime, but about every 5-9th stop.
    Could this be a sign of contamination in the system or is it an electronic issue? Is this something I can trouble shoot or does it require an Audi Doctor?
    98 A4 Quattro.
    Rick
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Re: ABS activating at slow speed??
    Wheel speed sensor
    Veteran Member Two Rings 0000_a4's Avatar
    Aug 03 2004
    Chi-Town
    Try cleaning your abs sensor
    K04|Custom FMIC|310cc Injector|GIAC PC-16|APR Inlet Hose|2.5" Scorpion Exhaust Turboback|EVO MS DV|South Bend Stg II Clutch|Unorthodox LFW|18" BBS CH|RS4 Look Front|S4 Rear and Side skirts|Koni Coilovers|A.W.E. Drive Train Stabilizer| 6000k 50w HIDs|Valeo 1 piece Headlights| Stratosphere SS
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    They mean there could be metal particles on the abs wheel speed sensors. Take them out, clean them.
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Oct 12 2006
    Mississauga
    Thanks for the input, I have the wheel off, but don't want to pry and break anything. Does the ABS sensor come off the caliper or do I clean by taking off the rotor and going in that way?
    Rick
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Remove the harness hold down bolt if any, then grab the shiny metal part of the sensor and pull firmly while twisting slightly. Don't pull by the wires and if you have grease on your hands or the sensor, clean both first.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Cracked tone ring on one of the axles.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Oct 12 2006
    Mississauga
    With the wheel off and caliper off and even the metal sheild off, the wire comes througth the strut housing and the sensor is black and attached to the caliper. I don't see any lock ring holding it??
    Is it a press in fit? 98 A4
    There is a rubber boot between the caliper and the sensor, and flats on the sensor , but seeing as it is plastic I did not want to start wrenching on it for fear of breaking it.
    May 22 2008
    is full of crap
    sandville
    Does this car have brake wear sensors? That could be what you have found and I don't know those come out... so maybe find out for sure before pulling.
    Mine ABS sensors are made of shiny metal and located right by the hub. They do just press in.
    Oct 12 2006
    Mississauga
    I don't think I have brake wear sensors. On the passenger side the sensor I found is at the front of the car side and the caliper is on the rear side. On my German made XR4Ti the brake wear sensors are a wire attached to the brake pad, but on the Audi that is not present.
