Results 1 to 2 of 2
    Jun 18 2008
    Western Australia
    Boost Control APR stage 3+ Western Australia
    Hoping someone can help me out... currently only on standard N75 ECU control and hoping i can help the car boost earlier and more consistently (HP is tracking the boost with several ups and downs) 290AWHP @ 23.9PSIA i understand with more boost comes the requirementfor more fuel and the APR tune is not adjustable but hopefully i can tune the EBC to match? (contact for plot i'm not sure how to add the jpg here) thanks for any and all advice...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Boost Control APR stage 3+ Western Australia
    You shouldn't run into any issues using a EBC, the ecu uses the maf to know how much air is being forced into the engine so it will increase the fuel being sprayed by the injectors. Since your have a B6 it should also have a wide band 02 and the ecu actually uses it all of the time to hit a set AFR programmed into the tuning.
    Plenty of people have used EBC's without any issues, I have been running a EBC on my 2000 since 2001 when I went with the PES T28 kit.
    To post a picture you need to host the picture online somewhere, you can even upload it to your gallery here on AZ. Then just copy the link to it, click on the small picture icon just above where you make your post and insert your link info into the window that pops up.
