Originally Posted by
AudiA4_20T
LOL, 2psi thats a big gain.
Like I said, if you do buy it just do some testing and see if your 60 ft times get any better using it vs doing a normal WOT launch.
BTW I sure hope you dont think its going to help you get out of the hole with a huge turbo that you plan on going with, because you are just fooling yourself if you think it will. The only thing you are going to gain is flat shifting and thats only if you can set it to a high rpm setting that wont cause the engine to bog down and still allow you to shift since our cars dont flat shift when running it to 8000+ rpms. I have even tried flat shifting with mine set at 5k rpms and it would lock me out from going into 3rd gear most off the time. This is why I stop even trying to do flat shift with my launch control/anti-lag on my stand alone and just doing normal shifts to run 10's.
AudiA4_20T
there was 1 video with 6psi, but reguardless its not nothing... and the flatshifting is nice
It wont be "nothing" because the throttle plate is fully open, so it isn't like the gauge would ever read vacuum at that point. The turbo still isn't spooling enough to make a difference at that point.
I used to have a video of my gauges doing a anti-lag launch and my gauge hitting over 30psi.
