    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Clutch Pedal Vibration
    Drove about 2 hours to Delaware today from NY and when i as gettin off the exit, i clutched in, and the pedal was vibrating. Like a steady pulse, and felt like the engine was misfiring. I stopped and at idle it was still the same. I had a meeting in 15 minutes so i didnt want to turn the car off and risk it not turning back on and since i was 5 mins away,i decided to continue driving.
    1st gear take off was really ruff and underpowered. As i got to the parking lot. i turned the car off and started it back up and the pulsating stopped.
    Any clues on what could be causing this? i was thinking maybe the hydraulic system?
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Dec 24 2007
    New York, NY
    Re: Clutch Pedal Vibration
    bump? anybody knows ?
    Dec 24 2007
    New York, NY
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    My clutch only vibrates when the AC is on.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Aug 26 2005
    Could be many things, but as a practical matter you can limit the scope to either a bad ignition coil pack or wear or damage to the clutch pressure plate assembly. It's almost certain that the symptom you described is a bad coil pack, the clue is that the symptoms disappeared on restart. That is consistent with a intermittent failed coil pack. Was there a Check Engine Light ON and or Flashing at the time the vibration/misfires occurring? If it was something mechanically whacked with the clutch, it's unlikely that it would suddenly be OK on restart. Get the engine ECU scanned for fault codes, I predict there is a misfire DTC for one of the cylinders. If a failed coil pack is confirmed by a stored misfire/cylinder# DTC, replace that cylinder's coil pack and clear the fault codes.
