Results 1 to 3 of 3
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Bad coolant leak!!! help asap!!!
    We tried searching but couldnt find anything relatied to this.
    after a couple of runs with a buddy`s chipped S4, the car overheated bad and it was leaking coolant towards the front ( on the 2001 S4, not my little 4 cyl). I see a metal cross pipe right in front of the oil pan. We checked it and we can see that is coming from somewhere from the top of the oil pan. is dripping like hell when we pour water to check for leaks, but it is not visible. can someone please tell me what is up there, or where to check?
    thank you in advance.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Re: Bad coolant leak!!! help asap!!!
    It's my s4 we're talking about. Basically water is just pouring from somewhere in the general area of the area right on top of the oil pan. Seems theres a little perch or something, with some steel cross line running alongside the oil pan.
    anyone?
    --Black 2001.5 -S4- 10secS4 Tuned
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    most likely is the water pump :(
