Results 1 to 8 of 8
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Broken Axle Bolt URGENT HELP
    So I'm torquing down my new axle bolt (to the tranny) at 30ft-lbs like the DIY says and it snaps. Part of the bolt is in the tranny and the rest came out. What do I do???!?!?!
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    Re: Broken Axle Bolt URGENT HELP
    get an easy out and a new bolt.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    worst case dril out the center and use an easy out.
    May 30 2004
    1997 1.8TQM
    I guess I'll have to do some more research about easy outs.
    I'm wondering what to do though... the first bolt I tried to torque turned FOREVER and then stripped. It wasn't that hard to turn, but it kept turning. Thinking I just slipped with the wrench, I started the second one. Same thing, turned a long time. Finally, snap! I'm so let down. I'm doing all of the control arms and both axles and it has been taking forever but I've overcome every feat I've faced yet. Torquing down these axle bolts seemed like the icing on the cake... but I guess not.
    If worse comes to worse and I decide I can't do this myself, would I be able to drive about 10 miles (carefully) with 5 bolts in the axle? The 5 bolts might not be properly torqued but I don't know what to think since the bolts are breaking.. they are either very tight or I'm doing something wrong.
    It sucks because I still have to do a lot of work before I can even get the wheel on to drive somewhere.
    Oct 29 2005
    10speed
    San Francisco, CA
    if the 5 bolts are tight enough you could probably drive forever and never notice
    - Clint
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    this is just a suggestion but are you sure you weren't using 30N-m? it sounds like a stupid question but most people make little mistakes like that sometimes. i personally know someone who changed his axle on his 2.8 and he had no problem with the torque setting
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    May 30 2004
    1997 1.8TQM
    Quote Originally Posted by hiwords1 View Post
    That's exactly what my first thought was since all of the torques supplied for the control arms are in metric but I rechecked the DIY and it says 30 ft-lbs. I guess it's entirely possible the DIY (on Audiworld) is wrong, but I'm thinking I may have messed something up. First of all, the bolts are not OEM or OE, and seem somewhat cheap. They aren't even the triple-square ones I took off the car; they are a 6 mm allen.
    Another thought of something I may have done wrong was a put the axle into the hub before I torqued them down. First I hand tightened them on the transmission (the six) and then I put the axle in the hub and tightened the large axle bolt enough to keep the it in place so I didn't have to worry about it moving around. I'm wondering if that extra force working against me torquing the bolts down had something to do with it?
    After I stripped the first bolt I took my torque wrench over to a lug to check to make sure it worked; it clicked instantly. When I was putting on the axle bolts I had several extensions and I was pull it up instead of pushing it down as I normally would like to. Not sure if this had anything to do with the wrench not clicking.
    I just want to pinpoint what went wrong so it doesn't happen again!
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Sorry about the breakage, M.719.
    According to the book, 30 FT/LBS is correct for the 8mm axle to transmission flange bolts. As long as the extension is just a plain straight one, it should not affect the torque wrench. A universal joint or angled or dogleg extensions will.
    Best way to use the things is to pull steady, slow and firm til they click. If it turns into a major nightmare with the broken bolt, you can always pull the flange and take it to a machine shop. Best to replace the seal if you pull the flange. Its easy to get at with the flange off.
    Hit your local library for the professional Chilton or Haynes Import manuals for good references on the job.
    Oh, yah, I would DeF get another TQW to verify yours is on spec before cranking anymore bolts down. They are cheap enough to rent from a decent autoparts.
