Results 1 to 20 of 20
    Veteran Member Three Rings SilverBiturboS4's Avatar
    Sep 14 2006
    Dallas,tx
    My ride is SICK!
    well my car is not well. here's the problem
    after every drive my car seems to want to puke out coolant from the hose that is at the bottom of the tank that goes to no where. no coolant leaks anywhere else but there. i have filled the tank up twice now and it puked it all out every time.
    every bit of help well be appreciated.
    TIA
    2001.5 S4
    Registered Member Two Rings drewwynn's Avatar
    Jun 03 2008
    01.5 S4 Avant
    Michiana
    Re: My ride is SICK!
    you mean the overflow hose? Are you adding too much coolant then its getting hot? Do you have a "low coolant" warning?
    Nogaro S4 Avant 6-Speed
    Stage 3-
    K04s, GIAC Stage 3- Tune, 5 Bar FPR, Samco TBB, 710ns
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Bad thermostat?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Sep 14 2006
    Dallas,tx
    going home one night my coolant light came on so i didnt think much of it. I filled it back up the next day before i left for work. it was fine when i went to work felt fine when i went home but it wasnt. the car starts to puke out coolant until it was empty. I didnt know it was empty until the next day i woke up and went to work. so now i filled it back up this morning and went on to work and now i get home and shut off the engine its pukes out more coolant. so i fill it up again and will have to get more coolant since i used it all already
    2001.5 S4
    Jun 03 2008
    01.5 S4 Avant
    Michiana
    Hmm, are you sure its out of one of the hoses that go nowhere? Look behind the block where the temprature sensor is and see if there is dried coolant everywhere? When you filled back up was there any white smoke from coolant burning or did it all just go straight down?
    Stage 3-
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Perhaps your after-run pump is shot and isn't flowing the coolant through after you turn your car off.
    --Adam
    Have questions? E-mail me.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by SilverBiturboS4 View Post
    ANY light on the S4 means something LOL. even the seatbelt warning may mean your buckle is effed.... every time i start im like come onnnnnnnn no light, YES!
    Sep 14 2006
    Dallas,tx
    Quote Originally Posted by 1997gtx View Post
    --Adam
    How would i now if the after run pump is gone?
    2001.5 S4
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Either the after run pump or your head gasket. Do a head gasket check if you know how or take it in and have them chack. Anytime coolant pours out of the overflow tank it's not good.
    Sep 14 2006
    Dallas,tx
    well i had my head gaskets was changed out about 10k miles ago when i did TB. could that have gone bad that quick?
    2001.5 S4
    Feb 29 2008
    Durham/NC/Southeast
    could just be a bad coolant cap. We see a lot of them bad. If it doesn't hold pressure the coolant will leak out that overflow hose.
    Jan 03 2008
    Iowa
    X2 ^^
    Jan 03 2008
    Iowa
    If you cant figure it out your best bet would be to take it in and have someone certified take a look.
    Dec 06 2007
    Calgary, AB, Canada
    When I saw the OP, my first immediate thought was "bad coolant reservoir cap"
    Try changing it (it's cheap) and if that doesn't solve the problem, then look into the headgaskets. When you had the TB done, they likely swapped the valve cover gaskets, not the head gaskets.
    Sep 14 2006
    Dallas,tx
    Quote Originally Posted by Evan@Absolute View Post
    I'll give that a try and hope that solves the problem.
    Quote Originally Posted by GetAwayFromMe View Post
    I was Hoping i would have to do that but if i cant looks like i have no choice but to take it to one.
    Quote Originally Posted by The_Jerbel View Post
    I'll call up to the shop that did my TB and find out what gaskets have been change out for sure because i went stage 3 at the same time. and he said he changes out some seal and gaskets since they were going bad.
    I've notice that my coolant tank doesnt have the little basket right at where you would fill up the coolant at. will that cause the problem?
    2001.5 S4
    Dec 06 2007
    Calgary, AB, Canada
    You mean the filler filter? The coolant tank doesn't have a filter basket. The expansion cap is designed to hold a certain amount of pressure, and if it goes bad, it starts to hold less pressure, causing the coolant level in the tank to rise when it becomes pressurized. This causes it to come spewing out the overflow hose.
    Jan 03 2008
    Iowa
    I don't think they did your headgaskets because you would be charged at least $800 extra just to do that job. Like someone already said they probably did your valve cover gaskets or maybe your cam seals and what not. Most likely it's your headgasket so prepare to shell out some good cash.
    Sep 14 2006
    Dallas,tx
    Yes I have notice that thing missing. but i just that wouldnt be a problem. ill go get a new cap at the stealership today and see if that fixes the problem
    2001.5 S4
    Sep 14 2006
    Dallas,tx
    Damn This SUCKS. thanks for the help. Im gonna go down the line one by one .
    2001.5 S4
    Sep 14 2006
    Dallas,tx
    I have changed out the Coolant tank cap and refilled the fluid. I will let yall know if that fixes my problem
    2001.5 S4
