2002 1.8tqm with 102k completely stock
Recently APR 1+ at 100k
Added: Forge 007 installed reverse with Yellow Spring
New R revision coil packs
New NGK BRK7E spark plugs
Problems: LEAN code once with misfires so changed Coil Pack and Spark Plugs. No Recurring CEL/code problem.
When i chipped the car. Boost was spiking at 21psi no problem. Less than a week later Boost spiked at ~15psi. Then Spike went down to ~11psi.
Changed: a check valve above airbox. Rechecked the DV connections. After i checked the DV, my spike is ~8psi.
Currently: MPG has gone down drastically around 15mpg. But weather in So CAL has been hot. Don't know if that's a factor.
QUESTION: if there is a leak from the small VAC Line on the DV, can that cause boost leak? VAC is fine on my boost gauge.
Also just got an ebay vag cable and found a code:
16684 -random multiple cylinder misfire detected
p0300 -001- upper limit exceeded - intermittent
What do you guys recommend i do? There is no CEL present. Just Boost guage showing boost lost. could be from DV area as that is the only area i touched.
Summary: NO CEL , Present boost leak, VAC is fine at -20mmhg
Thanks in advance
-anthony
also need to do a rear coolant flange, fun.
