Originally Posted by
matt719
Nevermind got it. The pinch bolt was frustrating in the way a thunderstorm ruins your picnic. These lower control arm bolts that connect to the subframe are frustrating in the way your brother pours a bucket water over you. I don't get the hype about German engineering-seems sloppy as hell to me.
Nah, its designed this way so you just end up paying them to do it for ya
If you loosen the three bolts (one 18mm two 16mm I believe) that hold the jacking point thing to the subframe you can stick something in there and lever it down to give you more room for that bolt.
