Results 1 to 33 of 33
    Nov 12 2007
    Grand Junction, CO
    Vibration Issue....From Spacers?
    Hey all....
    I had my coils raised today to 25" in the front and left the rears the same. Looks great. I also had an RS4 rear sway bar installed today. What a huge difference that makes! WOW!
    Now, for the problem...I had 8mm (H&R Trak Spacers) spacers installed as well, on my front wheels. Upon driving the car, I have found I have a vibration has a peak at 60 mph and lessons above that and under that speed. Does anyone know what that's from? Could it be that the bolts were torqued down to tight?
    Eddie
    Nov 12 2007
    Grand Junction, CO
    Re: Vibration Issue....From Spacers?
    Just got off the phone with JB at Perf-Cafe. Thanks for the SWAY man! Still can't believe the difference. I'll get to the bottom of this tomorrow. If anyone has any ideas though, please respond.
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    As I've posted a million times before. I really think it's the Quattro system that causes these vibrations. I have none of this 90+ MPH, but just between 75-90. I've test driven other Quattro's and 4MOTION's and they do it to at the same speeds, to a lesser degree on stock suspensions. My conclusion is therefore: lowering causes this to amplify, just have to deal with it. I've had everything thoroughly checked out, fucked with tire pressure, torque specs, everything.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    I just owned a Quattro Audi TT, slammed on coilovers, 19" wheels, spacers front and rear. I had no vibrations whatsoever at any speeds.
    You just had the spacers installed when the problem started, so they have to be the problem of course. They were installed incorrectly. First, clean the hub and remove any look rust that could cause an uneven contact. When you install spacers, you have the pound the shit out of them with a rubber mallet to get them on the hub all way. Pound pound pound away until you don't see any gaps anymore, then hit it a few more times. Torquing the wheel down normally won't get the spacer all the way tight against the hub either, so I always hit mine to be sure they're seated properly.
    Also, I would recommend using some antiseize or something on the back side of the spacer. Even after only one season, they get stuck on your hub and are extremely hard to get off. Truuuuust me. Wheels just sit on your hub, but spacers are on there VERY tight. I've never been able to get one off with just my hands.
    Come fall, you'll see tons of threads where people are asking how to take spacers off because everyone is taking off their summer wheel/spacer setup lol... Antiseize is a little messy, but it makes it so much easier to get these off. Prepare to make a road trip to frustration city if you leave these on half a year and expect them to come off as easy as a wheel.
    After that, all I can say is tighten your lug bolts while the wheel is off the ground in a star pattern at 88ft/lbs. Good luck
    Ignorance is bliss.
    Nov 12 2007
    Grand Junction, CO
    Thanks man. I'll have them try this tomorrow. Basically, you told me the same thing JB at Perf-Cafe told me. As for spacers causing vibs...I also think that is BS. I've had 15mm on the rear now for a month and no vibrations at all. None.
    Jan 24 2007
    Wisconsin
    Yup, they can and probably will cause vibration (like an unbalanced tire would) if they are the least bit loose or crooked. Otherwise you'll never even know there are on there
    Ignorance is bliss.
    Nov 12 2007
    Grand Junction, CO
    that's exactly what it feels like. An unbalanced tire. Hopefully its a simple fix.
    Jan 24 2007
    Wisconsin
    It is, just jack up one corner at a time and reinstall the spacer and wheel. Maybe 15 minutes a corner tops
    Ignorance is bliss.
    Veteran Member Four Rings TooLow2.0T's Avatar
    Feb 13 2004
    Portland, OR
    Quote Originally Posted by AudiWxGuy View Post
    In my experience larger spacers make it easier to get the wheels on straight since they will have a hub extension. It's much harder to get the wheels centered with 8mm spacers because the wheel hubcentric ring does not fully contact the hub in most cases. Also, you are much less likely to feel a vibration from the rear wheels anyway since it won't be transmitted through the steering wheel.
    Current: Tundra Brown 2015 Audi Q3 Prestige Quattro | Black 2013 VW Jetta
    Previous: Brilliant Red 2007 Audi A4 2.0T Quattro 6MT S-Line Titanium
    Nov 12 2007
    Grand Junction, CO
    Good point!
    Veteran Member Four Rings MAlby7's Avatar
    2017 Infiniti Q50S (HIS), 2014 Nissan Rogue (Hers)
    Woodbridge
    There's a large thread on this vibration at 60mph (90-100kmh). All cars do it. I've brought my car in twice to get them to check it, and both times they couldn't find anything. I've tried different tire pressures, different wheels, re-balancing wheels, and still the same shit. I think it's a resonance frequency at that speed which causes the steering wheel to shake. No one has found a fix for it and there probably will never be one.
    Nov 12 2007
    Grand Junction, CO
    My car did not do this before the spacers. No vibration at all. So, although your hypothesis is welcome...it does not pertain in this sense.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I also second the notion that they have to be installed incorrectly, good luck fixing it asap
    Nov 12 2007
    Grand Junction, CO
    I'll have an update tomorrow. I'll also have a pic of the new setting later. Once I get home and I can get the pic off my phone.
    Nov 12 2007
    Grand Junction, CO
    Pics of the adjusted suspension. The front was raised a bit to reduce some of the rake, and make the car look a little more smooth.
    Active Member Two Rings vedran's Avatar
    Jun 25 2008
    Norway
    We have same wheels (but I have only original sport suspension) and I'm thinking about spacers. What would you recomend now after trying 8mm on front and 15 aft? I just want nice look , nothing to much out....
    Nov 12 2007
    Grand Junction, CO
    They look nice together. I'm just trying to get rid of this vibration. I'm headed back to the shop in a few mins to get this looked at.
    Established Member Two Rings hhuynh14's Avatar
    Jul 01 2008
    2008 A4
    Orange County
    yea for sure the spacer is not set properly... I had the problem with the 8mm spacer.... only did it at higher speed pass 45 mph.... you just need to realign them and bolt the bolts correctly, in a star pattern and is should be ok...
    Jun 25 2008
    Norway
    Show us some pictures how it looks from diferent angels
    Nov 12 2007
    Grand Junction, CO
    I am at the shop now. The bolts were put in with locktight yesterday but somehow managed to back out and were a little loose. We've got some stronger locktight on the way and hopefully that will take care of the issue.
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Quote Originally Posted by davis449 View Post
    What?? I'm on my 4th Audi quattro and I've never had a vibration in any of them. My B7 A4 is lowered to 25" all around on Ohlins SL and I have ZERO vibration. You may have improperly balanced wheels or an improperly balanced drive shaft.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Just curious. Why you're using locktite in the first place? I've never used locktite with any of my wheels and they bolts have never backed out. I basically torque them down to factory specs (89 ft-lbs) and re-torque after 50 miles. Also, are you using longer lugs to account for the added thickness of the spacer?
    FWIW, I never had any vibration issues at any speeds when I was running spacers (12mm Front /15mm Rear)
    Nov 12 2007
    Grand Junction, CO
    IT's possible that the studs may be bad. I'll have an update soon.
    Registered User Four Rings PerfCafe's Avatar
    Nov 27 2007
    is where we work on cars!
    Monterey CA
    Quote Originally Posted by mksap11 View Post
    Eddie is using locktite because of the 2.5" stud conversion kit that we got him ... we are narrowing it down ... were going to remove the spacers and just run the wheels with the studs to see if the stud kit is the problem or if it is the spacers ...
    Nov 12 2007
    Grand Junction, CO
    Just went for a drive with the studs on and spacers off and the vibration was pretty much gone. I'm going to leave the studs on for a couple of days just to make sure its not them. Thanks for the help JB!
    Jan 24 2007
    Wisconsin
    ^ That's some good service right there
    Ignorance is bliss.
    Nov 12 2007
    Grand Junction, CO
    Being sarcastic, or genuine?
    Jan 24 2007
    Wisconsin
    Internet is serious business, I don't mess around
    Ignorance is bliss.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    My spacers vibrate like a bitch. I'm getting some scotch-brite and a rubber mallet tomorrow when I change my oil, and i'm going to take the front wheels off at the same time.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Nov 12 2007
    Grand Junction, CO
    Vibration is something I'm not going to tolerate. H&R spacers should not vibrate. They are supposed to be hubcentric. If they are not, or were not made properly -- possible defect -- they will put the wheel out of balance. Do your spacers have the lip on them? I've heard that spacers w/out the lip may cause vibrations....
    Dec 25 2007
    '06 A4, 08 R6s
    My 5mm up front don't have hubcentricity and it vibrates bad enough to move the steering wheel. But the 8mm in the back are worse. I can hear the tone of my friends voices vibrating, and trust me, they let me know when they start to feel it.
    2008 R6s
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Quote Originally Posted by Zebman View Post
    For sure your 5mm spacers are not hubcentric. Are your 8mm's? Using non-hubcentric hubs is almost a guarantee of vibration.
    EDIT: you posted right before me. Change your spacers. My 15's in the rear don't cause me any issues.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Nov 12 2007
    Grand Junction, CO
    The spacers that we put on our cars need to be hubcentric. I have 15mm H&R hubcentric spacers on the rears and the car drives perfectly with them. I know the 8mm i got for the front are hubcentric, well they are supposed to be, but are either defective, or not sitting on the hub right. I wonder if I should go 12mm up front? Maybe that would fit better?
