Results 1 to 7 of 7
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Unlocking Symphony Radio?
    So my OEM radio broke before I bought the car, it came with an aftermarket deck. I bought an OEM symphony from someone on here, plugged it in, entered the code and have been enjoying my "new" symphony. Well I'm going to be pulling my ABS module tonight and need to unplug the battery terminals and can't seem to find the radio manual anywhere with the code in it, since it will be resetting when I unplug the battery.
    I seem to remember there's a way you can turn off the security on the radio? So that when you turn it back on it won't ask for a code, and will just go straight to working? Anyone know?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Unlocking Symphony Radio?
    Quote Originally Posted by sixfiveoh View Post
    I noticed on the later units they sometimes won't lock. My original radio did, (pre-facelift) and the only way to unlock it was to bring it to the dealer. I replaced the radio with a aftermarket unit all together.
    -18 718 GTS
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    i think there was a DIY on AW about useing a 9v battery to keep the radio runing and not have to disconnect it completely. i forgot where it was , but ill try to find it!
    May 19 2007
    Bay Area
    If you could find it, that would be great!
    SIXFIVEOHphoto
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    found it here you go!
    its replacing the the battery article. sorry, i wouldn't know where to find one of these either. GL.
    May 19 2007
    Bay Area
    Anyone know where to get one of these?
    SIXFIVEOHphoto
    Established Member Two Rings doublebogey2's Avatar
    Jul 28 2010
    Pittsburgh PA
    sixfiveoh
    Did you ever find where to buy one of these.
    Anyone know where to buy one of these?
