Results 1 to 9 of 9
    Established Member Two Rings Zonacat's Avatar
    Jul 24 2008
    La Jolla
    Is it the turbo???
    This has happened a few times to me, I'm new to the car, and to turbos.
    While driving spirited, sometimes in the higher gears, 4th/5th, I may let off the gas for a bit and then roll back on the throttle and I feel a slight boom/clunk sound. Hard to describe, but my only guess is that the turbo is getting caught between winding down and then suddenly needs to wind back up.
    Does this make any sense, is this normal, is my car busted, am I an idiot?
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    Re: Is it the turbo???
    yeah it sounds like the excess pressure being released
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Jul 24 2008
    La Jolla
    Quote Originally Posted by VZWalex View Post
    Okay, thanks. The boom/clunk happens when the throttle is being rolled back on, is that when pressure would be released, and do other ever feel this?
    Thanks for the response!
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    sounds more like drivetran slack. normal for any car, turboed or not
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    maybe its your downpipe hitting the aluminum frame piece? do you have stock dp/exhaust? or are you chipped? maybe you need a snub mount to compensate for the increase in engine/drivetrain movement
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Sounds like the drivetrain jerking, assuming you're Quattro. I get this when I let off the gas while leaving it in gear, and when letting out the clutch quickly into the next higher gear.
    Ignorance is bliss.
    Jul 24 2008
    La Jolla
    Quote Originally Posted by Phrost View Post
    Yes, quattro. Drivetrain sounds like a plausible answer. I will lift off the gas, then go to roll back on and there's a split second delay then I feel a jerk. I have never had quattro, and never felt this in any other car before.
    Jan 24 2007
    Wisconsin
    Yeah, that's all it is since Quattro is an all time awd system.
    One thing people do to help fix this problem (if you think of it as a problem) is buy a new snub mount. It installs in under 30 minutes, is easy to do, VERY cheap at about $30-40... The snub mount is just a big bushing that is the front engine mount. The only bad thing about it is the car will vibrate a tad during idle since there is less drivetrain slack, but it's not a big deal if it is installed correctly.
    PureMS, APR, and ECS all make one. Search around and compare prices
    btw, here are some DIY's to install one:
    http://www.audizine.com/forum/showthread.php?t=193034
    http://www.audizine.com/forum/showthread.php?t=165449
    http://forums.audiworld.com/a4b7/thr...98.phtml#23726
    Ignorance is bliss.
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    I dont think is has that much to do with quattro and more to do with the fact that it is just part of a car with a manual transmission because there is no torque converter, it will be harder to hide throttle movements and transmission slack
    All go no show
