Originally Posted by
CO AVANT
shares same master cylinder as brakes. The bleed valve for the clutch slave is located above the drivers side front axle on the top of the bellhousing (transmission) There is a little rubber nipple on it like the brakes have. Remove the coolant reserior for easier access.
Shares the same fluid reservoir as the brakes (they get fluid from the same location) however it does not share the brake master cylinder.
You have a clutch master cylinder which is attached to the pedal, and a clutch slave cylinder which is located on the transmission and has a plunger to push in the clutch fork and disengage the clutch.
The way it works is that when you press in the clutch pedal, the clutch master cylinder forces hydraulic fliud (brake fluid) through a small steel line into the slave cylinder, the pressure created by forcing the fluid causes the sleve cylinder to move and in turn it moves the clutch fork. The clutch fork in turn moves the clutch diaphram and releases the pressure off of the clutch pressure plate.
The way the clutch engages is that the pressure plate clamps down on a disk that is connnected to the tranasmission via splines, when there is pressure from the clutch disk, it is mated to the flywheel and transfers the rotation of the engine to the transmission.
When you disengage the clutch (by pushing in the pedal) it allows the disk to spin freely by releasing the clamping pressure put on it by the flywheel.
The reason it is important to bleed the clutch is beacuse the size of the master cylinder and slave cylinder are very small in comparison to the amount of pressure it takes to disengage a clutch, the reason they are small is they have to be proportionally smaller than the hydraulic brake system, if they were any larger, as the clutch begins to wear, you could potentially use all of the fluid in the reservoir for the clutch, leaving none for the brakes.
Brake fluid is typically good for no more than two years if your car is driven normally, if you drive hard like I do, you need to change your brake fluid every six months or year.
High performance brake fluid (such as Motul RBF) also condenstes (collects water) very easily and should be changed after track events, canyon carving and anytime you tend to overheat your brakes.
If you bleed your clutch, you will have better performance, a longer lifespan and your third gear synchros will last longer.
