Results 1 to 26 of 26
    Veteran Member Three Rings LEGO's Avatar
    Aug 20 2007
    SEATTLE, WASHINGTON
    smoke during idle
    So here's the problem I'm having. My ko4 blew two weeks ago. I bought a new turbo from gpopshop.com, put that in a week ago. The car was smoking for a while cause I figured there was a bunch of oil and other crap in the exhaust and it had to burn out. I did two seafoam treatments through my intake lines to help clean it out. Now I'm not getting any smoke out of my exhaust while I'm driving. When I first start the car there is no smoke. After driving the car a bit and letting it warm up, if I stop at a stop light or just let it idle, white/blue smoke comes out of my exhaust and it smells like burning oil. What would cause this problem? The turbo is brand new and if it was leaking oil into my exhaust, wouldn't that happen when the turbo is stressed most under boost? Is there still oil in the engine that hasn't burnt and is burning up from the blown turbo? I checked my oil and it's a little overfull on the dipstick. Would this cause the smoke? Performance is not lacking at all though. The turbo hits hard and pulls well and smooth. It's just anoying that when I'm at a light, people give me dumb looks like there's something wrong with my car and I don't know it. Please let me know if anyone has any ideas. Thanks!
    1998 A4 1.8TQM MTM K04 5.82/034 415CC BT TUNE/GENESIS 415CC INJECTORS
    http://s22.photobucket.com/albums/b331/nelly11299/
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Re: smoke during idle
    Don't know if it will work for you but I took mine to the shop about 6 months ago for an oil change and then my exhaust started smoking lightly while idling. I checked the dip stick and it was overfilled. I drained some oil (after it was cool of course) and no more smoke, clean as a wistle. I always do my own oil changes now.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Reason being, oil gets burnt by your converter.
    Veteran Member Four Rings GQ//S4's Avatar
    Jul 25 2007
    Today?
    North of Seattle in trees, WA
    The best is when we were at the stoplight the day after the turbo went in, and the guy on the motorcycle behind us had to sit at a red light for a couple of minutes while your exhaust was billowing oily smoke all over him. That made me laugh
    - Michael
    Fact: I'm Awesome
    Former: '92 911 C2, 01.5 S4 Stg 3, 00 S4
    I always dreamed of walking on clouds, so I drive on air
    My logic is infallible. Always.
    Grammar Nazi #1
    "I'm too close for missiles, I'm switching to guns!!!"
    Aug 20 2007
    SEATTLE, WASHINGTON
    Well, I just changed my oil again. I've always put 4.3 quarts in because I thought that was the oil capacity of the 1.8t, but after putting 4 quarts in, letting the car idle for 5 minutes and then checking the dip stick again, it was full. Kinda wierd. Does anyone know if the oil capacity for the 1.8t is 4 or 4.3 quarts?
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    its 4 quarts only. any more and you overfill it. i used to change the oil on Audi's all day
    Nov 21 2007
    The Sticks
    What size filter do you use? If you use the large one it might take a little bit more, depending if you drained all your old stuff out all the way. I ususaly use 4 though maybe a little bit more.
    2001.5 1.8t
    Aug 20 2007
    SEATTLE, WASHINGTON
    I always use the large oil filter. I drained as much as I could. Left it dripping for a while too. Changed it when my engine was hot by the way and ended up burning my hand by trying to loosen the oil filter. Couldn't get that darn thing off, then finally figured out that I can get a screw driver between the two humps on the bottom and twist. Loosened right away! Can't believe it took me like 10 minutes to figure it out. Anyway, put 3 quarts royal purple in, 1 quart of the lucas oil addative. Let it idle for 5-10 minutes, then checked the dip stick level. Ended up right at the full line with only 4 quarts.
    Aug 20 2007
    SEATTLE, WASHINGTON
    I'm still getting this. It's wierd because it smokes during idle, but then once I start moving from a stop light, the smoking stops. What else could be causing this?
    Nov 21 2007
    The Sticks
    Are you sure it's oil burning? It's not coolant burning, clear slightly white and thin and you can only see it at idle because it's thin and when you drive it disapears.
    2001.5 1.8t
    Aug 20 2007
    SEATTLE, WASHINGTON
    Huh, It's possible. What would cause my coolant to burn? Why would it leak into the exhaust?
    Nov 21 2007
    The Sticks
    Could be coolant in your cylinders and when ignited it burns up. Is your coolant level getting lower slowly? Do you only get it on start up or does is still do it when it's all warmed up? Is it thick smoke or very light?
    2001.5 1.8t
    Aug 20 2007
    SEATTLE, WASHINGTON
    My coolant is getting low slowely. No smoke at start up. No smoke when I'm driving. After my car is completely warmed up, if I stop and let it idle, it starts smoking right away. Smoke is pretty noticeable. White smoke and smells. As soon as I start driving, no smoke. It's not crazy thick, but noticeable. I can see it through my tinted windows. What do you think would cause this?
    Veteran Member Three Rings Naudilos's Avatar
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    Did you ever find out the cause of this smoke? Seems like I'm having the same issue.
    01.5 A4 1.8t Quattro Tip
    - Greddy III Turbo Timer - GIAC-X/Tip Chip - PSI Test Pipe - 2.5" Magnaflow Turbo-Back - S4 Euro bumper - UBERHĂUS RS4 grill - M3 Lip Spoiler - ProSport boost guage - Euro trunk lid - H&R Race Springs/Bilstein Shocks - S4 Side Skirts-
    18" RS4 DTM - 710n - 20% tint windows/tails/side markers - 6000K HID's -
    Jul 28 2008
    Everywhere
    I was having the same issue and couldnt register my car because it was like the car was on fire. But i put some stop smoke and stop leak in and all was good until today when i replaced my coils and spark plugs began to smoke again and then it went away drove for like 50 minutes and got my e test done and passed with flying colours
    Aug 20 2007
    SEATTLE, WASHINGTON
    Naudilos, I haven't figured it out yet. What turbo do you have? Is it a hybrid ko3/ko4? Cause it seems that people with the hybrid have the same problem.
    Junaid, what kind of turbo do you have? I will try what you said. I saw some of that stuff at walmart the other day, but I didn't know if it would help or not. I'll give it a try. Thanks! Keep you guys posted
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    I just have a stock K03S turbo. I'm boosting 21psi easily if I want to. So I don't really see it being turbo failure, since it's not burning oil when I'm boosting. I only get smoke when it's warmed up and I come to a complete stop for more than around 30 secs. Some times it takes a few mins of being at a complete stop. The smoke comes out pretty white, maybe a little blueish, and then stops and the problem goes away. It's very inconsistent when it occurs, makes no sense to me.
    Senior Member Two Rings This Is Epic's Avatar
    Jan 07 2008
    VA
    I'm having this same issue, but it happens at start up sometimes also. I am also losing coolant very slowly.
    I think mine is the cause of some sort of exhaust leak around the manifold.
    Established Member Two Rings 1.8t's Avatar
    Jul 25 2008
    Anybody figure out the problem?
    Jan 07 2008
    VA
    I haven't, I hope to find out more this weekend when I get some free time.
    Aug 20 2007
    SEATTLE, WASHINGTON
    Well, mine stopped smoking and only does it once in a while after long trips. I don't know what caused it to go away. I always use lucas oil stablizer and I added some stop smoke stop leak from walmart. I don't know if I can say that the stuff actually helped my exhaust stop smoking or if all of the oil from the blown turbo finally burned up out of my exhaust. Give that stop smoke stop leak stuff a try. It's cheap at walmart. I also cleaned out my exhaust tips. There was a bunch of caked up oil in there. I sprayed some engine degreaser in the tips, let it sit, then washed and wiped it out.
    Jul 28 2008
    Everywhere
    Sorry about the late reply i will take a pic or write down the name the next time i go to my car, but check the big pipe from your engine to your intercooler or turbo not sure which one it is but see if that has oil in it. Mine does and thats why my car smokes still sometimes.
    Jul 28 2008
    Everywhere
    Quote Originally Posted by This Is Epic View Post
    If your losing coolant slowly you have a head gasket leak, i suggest you take it to a mechanic before it is too late. You can DIY for about $500 other wise you are looking in the ball park figure of $1500 to fix. Alot of labour in there.
    Jan 09 2008
    88'90quattro 98'passat quattro 05. Usp a4 571whp 97 a8 00 TT 99 Passat 2.8l 5 speed 99 Passat 1.8.
    haverstraw ny
    there are couple of possible problems, it might be the turbo(just starting to go bad), might be the head gasket(not common) or the valve seals (if it only smokes blueish smoke at idle or after a couple of min of idling)
    is the smoke blueish or white
    white is antifreez
    bluish is oil
    black is toooooo rich.
    Jan 07 2008
    VA
    Quote Originally Posted by Junaid View Post
    I replaced the head gasket about 2 months ago when my TB went. Plus if it was a head gasket issue wouldn't coolant be in my oil?
    Jul 28 2008
    Everywhere
    if you replaced your head gasket already...then try some of this stuff maybe your gasket wasn't seated properly?
