Results 1 to 11 of 11
    Veteran Member Four Rings So_NAudi's Avatar
    Jul 11 2008
    Dead Hookers, Kilos of blow and an asston of pokemon cards.
    43.07°N 87.97°W
    Neutralizing Wash.
    I had a bad caliper that was rubbing metal on metal and it sprayed metal shavings all over the back of my car that have stuck and rusted. Correct me if im wrong because im new to detailing, but a clay bar wont take that off, right?
    And i have heard a lot about neutralizing washes, would that help?
    -Alex
    ¯\_(ツ)_/¯
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Re: Neutralizing Wash.
    Those metal shavings...can you see them? Or you can only see them because they have rusted?? Clay can remove quite a bit...depending on the grade of the clay. Try a mild clay, you can pick it up at PepBoys, Autozone, ect. Clay Magic is a good OTC product...give it a try, it should solve your problem.
    Neutralizing washes...im not an expert on, so I cant give you any tips...never exoereiced them.
    Goodluck!
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
    Jul 11 2008
    43.07°N 87.97°W
    when i rub my had across the surface, it is not smooth. Also it looks like little rust colored flecks in the paint. After i wax, my towel i wipe it off with is rust colored also.
    -Alex
    ¯\_(ツ)_/¯
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    clay.
    enough said. trust me.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Veteran Member Three Rings Alan's Avatar
    Jan 22 2007
    1998 2.8QM 1988 Corvette
    Pittsburgh, PA
    try clay for sure.
    May 13 2007
    Northern VA
    You're probably going to marr the paint if you clay. So if you do that, you should be prepared to polish it. Otherwise I would go with the non abrasive method of a chemical wash first. Least abrasive method first.
    - Dan
    Jun 03 2007
    california
    Quote Originally Posted by 04audiA4 View Post
    I highly doubt that any type of wash can take away rust or metal shavings. The non abrasive method of washing is useless and is only used to take off light dirt not rust. If there are any type of chemical wash strong enough to take off rust it will strip or damage your clear coat anyways. use clay.
    May 13 2007
    Northern VA
    Quote Originally Posted by got boost. View Post
    I dont think you're aware of what Im talking about. http://www.autoint.com/autostore/pc/...&idproduct=225
    - Dan
    Jun 03 2007
    california
    i never seen this product before but it would make life easier if it took off containments that clay bars would. i wonder why i never heard of it through any of the professional detailing websites. Do you have any experience with it proving it works?
    May 13 2007
    Northern VA
    I have the kit, but havent used it yet. Im planning to test it out on a car that sits outside 24/7. From what Ive read, it takes off A LOT of contaminants that claying removes, plus some. But not quite 100% of them. So claying after might or might not be necessary. Of course every car will be different.
    - Dan
    Veteran Member Four Rings Grouse's Avatar
    Sep 06 2005
    05 a4 3.0 Ultrasport
    Norwalk CT
    It would be my choice also. I would probably let the alkaline neutralizer dwell the full 15 min. You have to constantly spray it down and do light agitation with a crappy fiber mitt.
    FWIW i have done 30+ cars with this system and like it alot. Here is one I worked on a few months back.
    http://www.3lgautodetail.com/Photos.aspx?cid=26&gid=126
    USPClub Member # 32
    Nominated best detailer in western washington
    Chosen as one of the top 9 detailers in the US by autoweek.
