Results 1 to 13 of 13
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    Where to tap for gauge light?
    Where is the best place to tap off of for the light in my boost gauge? I currently have it on the headlight switch but im getting the light on dim whenever the car is on and full light when the headlights are on. Where would you recommend? It is a generic boost gauge with a pos/neg wires.
    Mar 18 2007
    '05 A4
    Tampa, FL
    Re: Where to tap for gauge light?
    bump
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    What are you trying to achieve.. a consistant bright light? If so you can use an add a circuit from an auto parts store and just piggy back switchable 12v source...
    Mar 18 2007
    '05 A4
    Tampa, FL
    no i just need to know where i can tap off of for the light in the gauge besides the h/l switch
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Depending on where you are installing the gauge, the best would be one of the lights in the vents. The dial on the left of each vent has its own light, which works on a dimmer, and there is only pos/neg wires coming off of them.
    This is where I wired mine, and it works great and with the dimmer. You have a do a little test to see which wire is the pos, I think it is black, and then you are set.
    These are the easiest wires to reach without tearing out any dash pieces. The vent just pulls out and the wires are right on the side. This is the best place in my opinion, so I hope this helps.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^^ that is what I am talking about... an add acircuit allows you to piggy back a fuse in your fuse box for switchable power, this how I powered my gauge... here is a pic where I added the gauge power to my reverse light power fuse so it turns on and off with the car...
    Jun 21 2008
    **EDIT** I made a mistake, the dials are on the LEFT side of the driver's side vents, and the RIGHT side of the passenger side vents.
    Mar 18 2007
    '05 A4
    Tampa, FL
    mine is on the column...how hard is it to get to the vent lights?
    Mar 18 2007
    '05 A4
    Tampa, FL
    bump
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I have the column podi too and the spot I showed works great.. But to each is own
    Mar 18 2007
    '05 A4
    Tampa, FL
    oops sorry i reread your post...that spot looks good. thanks
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    did you tap off of this wire for the headlight switch?
    http://www.a4mods.com/index.php?page...odiAnalog.html
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Agree with 04b6sport. I tapped the vent lighting wires and the gauge dims nicely with the interior lights
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
