Results 1 to 6 of 6
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    How many different ecu's?
    There is A box, M box, are there any other ecu's? Which ones go with what year/vin car?
    ThorTechnik.com
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: How many different ecu's?
    Dude check out S4wiki..I think that has what you're looking for.
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    You're missing H box (2001), T box (2002), and then there are separate designations for tips (B, J, L, AA). The A box and M box are for 2000 and 2001.5, respectively.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Registered Member Two Rings hosmer79's Avatar
    Jul 16 2008
    2001.5 Audi S4
    W.S., MA
    I found this when looking for myself before on GIAC's website
    http://www.giacusa.com/programs.php?mpid=59
    2002 B5 S4® (Tip) 8D0907551AA
    2002 B5 S4® 8D0907551T
    2001 B5 S4® (Tip) 8D0907551J
    2001 B5 S4® (Tip) 8D0907551L
    2001 B5 S4® 8D0907551M
    2001 B5 S4® 8D0907551H
    2000 B5 S4® (Tip) 8D0907551B
    Not positive which 2001 ECU Letters are for 2001.5 (if there even is a difference). I know my 2001.5 tip had the "L" ECU.
    Take care!
    Two is greater than one!
    2001.5 S4 Santorin Blue 124K
    GIAC - Darintake - Drop in K&N - 710n's
    http://i94.photobucket.com/albums/l9...orums/Sig2.jpg
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    is it true that M box is the fastest/best?
    Quote Originally Posted by ThirdStrike View Post
    If you've searched and have been here long enough you will know that ECU and year is irrelevant...color is what ultimately dictates what's fastest
    If you were being serious, it depends on what you mean by best and how you look at fastest. Strictly speaking in stock terms, 2000 S4's were a little lighter than newer ones and did't have ESP which could make it faster and better depending on what you want to do. Once mods are in the picture, I know for a while it was believed certain programming ran better on certain years, and with certain Stage 3 kits the Bosch MAF needs to be replaced, so in some sense the later S4's are better. At the end of the day, there's bigger things besides ECU and year that I would be concerned with...like color
