Results 1 to 2 of 2
    Jun 21 2008
    NYC | ATX
    PSS9 Install Question
    I have a question regarding the PSS9 Installation...
    Are the springs suppose to be somewhat "loose" after you install them onto the shock and onto the steel triangle piece, but before you put them into the car? They seem a little loose to me, meaning them can be moved easily.
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: PSS9 Install Question
    Quote Originally Posted by NYSpeedRacer View Post
    if you mean can they move side to side and its not actually seat by sliding the spring onto the coil strut then yes. you putting them in the car and it seating against the susp components are what tensions the spring. the rears, which the spring is independent of the shock, you'll have to sort of hold the spring in place as you jack the subframe back up into position. the seat where it sits will point backward and be crooked if you just let it sit on it without holding it.
