Results 1 to 19 of 19
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** AZ Intro - ARP 10mm Head bolts - FINALLY!! ***
    FINALLY....
    For all those Big Turbo,Small Turbo ,Fat Turbo,Slim Turbo,Juicy Turbo( ;) ) Build up this is for you!
    How did this happen?
    Well after sending ARP stock head bolts for months and coming up short, Javad Shadzi@034motorsports was nice enough to bite the bullet and send ARP an ENTIRE CRATE MOTOR in order to get these babies done right to our specs.
    Well Enjoy!
    Quote Originally Posted by Head Bolt Kit, ARP 1.8t 10mm
    AVAILABLE IN 10mm ONLY RIGHT NOW (11mm will be available shortly)
    ARP - The world leader in fastener technology has just released two new Pro Series ARP 2000
    M10 head bolt kits for 2000 and later Volkswagen/Audi 1.8L DOHC 20V turbo applications.
    Both kits feature an internal wrenching 12 point head which ensures easy installation and removal.
    All bolts are Pro Series ARP2000 bolts, cold forged to ensure molecular integrity, heat treated prior to thread rolling and machining, and are nominally rated at 220,000 psi. These ARP2000 fasteners deliver a 40% increase in tensile strength over the OEM Torque to Yield (TTY) bolts.
    As a bonus, they are reusable and do not require replacing.
    AZ Introductory Price : 205US SHIPPED
    + The Head Bolt Tool : 235US SHIPPED
    10 sets of these are ready to go for AZ peeps:
    1.
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    Thank You AZ :D
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: *** AZ Intro - ARP 10mm Head bolts - FINALLY!! ***
    lovely. i am in need of a set. Too bad they are not for my AEB head. sucks
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Jan 25 2006
    A4 2.0T
    MD
    Nice work guys.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Very nice.
    Waiting on the AEB stuff.......
    Jim
    I Do Werk.
    Feb 26 2006
    Earth
    AEB is coming
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    will be purchasing when they are available for the AEB head and when the GT30 goes on.
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Raceware wasn't cutting it anymore or what? It was a pleasure to finally meet you, introduce myself and have you walk away at WF, BTW.
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by Issam@034 View Post
    AEB is coming
    When is it coming? I got a AEB head sitting behind my chair for when I get my insurance money.
    -18 718 GTS
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by bassed View Post
    Well it seems odd seeing that everyone keeps saying upgrading the head bolts is pointless.
    Well I guess they felt that if they make it people will buy it.
    BTW the raceware is a stud setup while the ARP is a bolt, so the ARP kit should be better just because of that fact.
    Oct 06 2004
    Minnesota
    Damn I just bought raceware
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 27 2005
    North Wales, PA
    Oh shit...what size bolts do I need for an AWM with AEB head? I don't know if i ordered the right ones....
    Jul 07 2004
    socal
    Quote Originally Posted by Poopie View Post
    Well is the 10mm and 11mm the thread size or the thickness of the bolt/head?
    I am running a ATW block and AEB head, pretty sure I am using what the ATW block calls for.
    Feb 27 2005
    North Wales, PA
    uugghhh i ordered head bolts for an aeb block....and i need awm bolts. Its the thread size that changes.
    atw and aeb are both 058 blocks. same bolt either way. :)
    awm was when the change was made.
    contact via email please.
    Jul 07 2004
    socal
    Quote Originally Posted by k0mpresd View Post
    They are the same block but IIRC the head bolts are different for the AEB and the ATW. Look at the info in Issams post.
    2000 = ATW.
    Checked on 034 site and it lists the AEB for 11mm.
    058 103 385b. same part # for both engine codes. call your dealer. or check etka. you remember incorrectly. ;)
    awm is 06a 103 385a. nice edit btw.
    Jun 04 2004
    fairfield cnty, CT
    aeb and atw = same block
    Jul 07 2004
    socal
    Quote Originally Posted by ModifiedA4 View Post
    LOL, seems to be a echo in here.
    The question wasn't if they used the same block, but if the 10mm and 11mm size of the bolt kits are based on the threads going into the block or if it has to do with the size of the bolt holds thru the head since plenty of people use AEB heads on both the 058 and 06a block.
    BTW that news is about 7 years old.
    Feb 26 2006
    Earth
    Quote Originally Posted by Beemer832 View Post
    -josh
    The cylinder head does not matter.It is the block that matters.The AEB's have 11mm whereas all 06A blocks are 10mm
    No,customers complained about the price
    Sorry bro,was good meeting you too but I had to talk with Alex because there was an issue with unitronic and a 034 customer.I did not want to make it too obvious.
    10mm
