Results 1 to 20 of 20
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    ***AZ Intro - ARP 10mm 1.8T HEAD BOLTS - FINALLY!! ***
    FINALLY....
    For all those Big Turbo,Small Turbo ,Fat Turbo,Slim Turbo,Juicy Turbo( ;) ) Build up this is for you!
    How did this happen?
    Well after sending ARP stock head bolts for months and coming up short, Javad Shadzi@034motorsports was nice enough to bite the bullet and send ARP an ENTIRE CRATE MOTOR in order to get these babies done right to our specs.
    Well Enjoy!
    Quote Originally Posted by Head Bolt Kit, ARP 1.8t 10mm
    AVAILABLE IN 10mm ONLY RIGHT NOW (11mm will be available shortly)
    ARP - The world leader in fastener technology has just released two new Pro Series ARP 2000
    M10 head bolt kits for 2000 and later Volkswagen/Audi 1.8L DOHC 20V turbo applications.
    Both kits feature an internal wrenching 12 point head which ensures easy installation and removal.
    All bolts are Pro Series ARP2000 bolts, cold forged to ensure molecular integrity, heat treated prior to thread rolling and machining, and are nominally rated at 220,000 psi. These ARP2000 fasteners deliver a 40% increase in tensile strength over the OEM Torque to Yield (TTY) bolts.
    As a bonus, they are reusable and do not require replacing.
    AZ Introductory Price : 205US SHIPPED
    + The Head Bolt Tool : 235US SHIPPED
    10 sets of these are ready to go for AZ peeps:
    1. CO AVANT
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    Thank You AZ :D
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Re: ***AZ Intro - ARP 10mm 1.8T HEAD BOLTS - FINALLY!! ***
    So tempting
    Some fast things and some slow things
    ~Josh~
    Aug 26 2005
    These high strength head bolts should be considered essential hardware for all BT or stage 1 > engine builds.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by mtbrider View Post
    So tempting
    I know right? damn I might just give into these
    - Clint
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^ you might as well while you have the head off... :)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Your head is off. Might as well install them. If my engine wasn't together and running right now I'd buy a set. You send those pistons & rings up to me yet?
    -Doug
    Feb 26 2006
    Earth
    All PM's replied.Stop being chickens!! :P
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I might just buy a set then. You can install them with the head on. When I had problems with my head lifting and combustion gas getting into my coolant system, I installed all new oem bolts one by one in the proper sequence and it fixed the problem. This was with only 400 miles on the engine though, now have 2100miles. Issam can you possibly get a set out to me by Thursday or can I pick a set up on my drive down through Cali? I would like these in hand just in case. I already have a head bolt tool. OR maybe you could ship them to Greg's (400HPA4) house by Friday and I can get them there?
    Oct 29 2005
    10speed
    San Francisco, CA
    Issam I want to do it but i need a few days
    - Clint
    Feb 17 2005
    Sarasota, FL
    Who has head lifting problems with 1.8T's using oem bolts?
    Feb 12 2004
    Everywhere
    I don't know if my head was necessarily "lifting" but there must not have been enough torque or something on the oem bolts which caused the combustion gas to get into my coolant system which in turn would overpressurize the reservior/system and coolant would overflow out of the reservior to the point of empty. It would only really happen at high boost levels. I installed new oem bolts to spec + torque with the head still on the motor and haven't had a problem since. Hopefully the stockers don't stretch again to the point where i get combustion leaking again. I think these arp bolts will help.
    Mar 11 2008
    B7RS4 & e46Ms
    +1
    The mitsu crowd has been rockin these for years...considered a necessity.
    And yes, you can swap them out with the head on the car...
    Feb 26 2006
    Earth
    All PM's replied!
    Feb 26 2006
    Earth
    1 down...9 to go
    Feb 26 2006
    Earth
    Back up to the top.
    Feb 12 2004
    Everywhere
    Installed them yesterday. They look high in quality. Don't need that extra 90deg turn like the stretch bolts...
    Aug 26 2005
    Quote Originally Posted by CO AVANT View Post
    Because the ARP high strength bolts are not stretched from the torque applied, they don't have that "spring like" property that the OE stretch bolts have when tightened to the elastic stretch zone.
    Therefore, the ARP head bolts must be retorqued occasionally until the torque setting stabilizes, or according to the interval specified by ARP. To check the torque, the engine must be fully cooled off. Then using the bolt tightening sequence, one bolt at a time, crack each bolt in the loosen direction about 30 degrees, then re tighten using a smooth steady pull on the torque wrench up to the torque setting specified by ARP. It's important the torque wrench used is accurate. Recalibrate the torque wrench if the calibration is unknown or after the recommended used tightening cycles.
    Dec 25 2004
    Earth
    I prefer studs to bolts....
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    im in issam.. im def in!
    and al im doing is a GTRS haha
    but wanna make sure it a damn good setup.. get every bit of power out of my lil ol tip tranny. haha.
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    btw wish i had my integra.. then they only cost me like 100 bucks haha.
